Originally posted by stevebrot Did you buy the M42 or a K-mount version?
- M42 (adapted), you have to manually stop the lens down to meter and also at exposure time. Use the A/M slider at the base of the lens.
- K-mount (non-A contact) use M-mode and green button metering. Be sure you are configured to allow the aperture ring.
- K-mount (A contact) All exposure modes should work with the aperture ring in the A position.
Thanks Steve.
It is a K-mount, without the "A" contact.
So, OK, I would use the M mode plus Green Button metering, as you explain.
Yes, the camera is already set for allowing aperture ring and of course, I enter the focal length when turning the camera ON.
So, I assume that I have to follow the steps in the aforementioned thread :
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/110658-using-ma...x-dslrs-f.html ?
I am never too sure about the missing aperture info on the camera display; that lead me to believe (erroneously) that it always shot wide open.
I don't think it (aperture) would show in the EXIF data either .. right?
Cheers.
JP
