12-13-2012, 05:42 PM   #16
QuoteOriginally posted by Briton Quote
JohnX,
Thanks for your suggestions about the body/lens fit. I would LOVE to walk in to a store and discuss this with sombody, but have found nary a Pentax DSLR in sight in any store in Chicagoland (if anybody know of one, please advise). As for why I used Yvon's "Autofocus Adjustment Chart" (PENTAX DSLRs: PART-1. Autofocus Adjustment charts for front and back focusing problems. Good for Pentax, Canon and Nikon.), I followed those directions assuming that is what it was designed to help with. Using his chart, the line at zero (0mm) should be sharp, but when I tested, the line at 8mm was sharpest. With adjustment it was better, but still sharpest at 2mm. I simply don't have confidence my setup was spot on, but I will retest and try to post an example.
Thanks again,
Pam
You might give PJ's Camera a call. They may let you special order a lens or body and try it in the store when it arrives. But make sure to ask if they have a "restocking fee" if you don't want it.
adjustment, af, camera, correction, focus, k-mount, lens, light, mm, pentax lens, question, slr lens
Bad or normal copy of DA* 16-50/2.8? jpyykonen Pentax SLR Lens Discussion 9 07-04-2012 01:36 PM
Need help to confirm that my new K-5 and kit lens is not a bad copy kkx Pentax K-5 12 01-07-2012 02:53 PM
what is a good or bad copy of Da*16-50? nuaabill Pentax SLR Lens Discussion 20 11-13-2009 07:26 PM
Is my 50-135 F2.8 a bad copy, With photo samples m42geo Pentax SLR Lens Discussion 39 06-19-2009 01:49 PM
is my copy ok or??? 16-45's 45 mm vs 50-135 mm' s 50 mm hll Pentax SLR Lens Discussion 6 06-20-2008 09:03 AM
All times are GMT -7. The time now is 06:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
