12-12-2012, 02:13 AM   #1
tabl10s's Avatar
Can The K-5 Be Used With A Bellows?
Just curious.
12-12-2012, 02:34 AM   #2
Clavius's Avatar
Of course, I myself use this cheap Chinese bellows with PK mount for mounting enlarger lenses or microscope lenses.
12-12-2012, 02:48 AM   #3
Senior Moderator
Nass's Avatar
Yes, but bear in mind that to the cam, a bellows is the same as a non-compatible lens. So your flash options maybe limited
12-12-2012, 04:10 AM   #4
Fogel70's Avatar
It will work, but there might be some compatibility issues. like when I use my old Soligor K-mount bellows I can't mount my DSLR's directly on it, as the prisma-house/flash on the camera is in the way. So I have to use a 12mm extension tube between the camera and bellows.
12-12-2012, 05:08 AM   #5
p44f's Avatar
On Pentax M/A bellows unit I use my k7 without any problems. You have to remove battery grip and you have to have the lens with the aperture ring so that you can close aperture.
12-12-2012, 05:44 AM   #6
Bob from Aus's Avatar
I have a k thick chunky adapter on my old pentax m42 bellows thread. Don't try the pentax adapter as your bellows can get stuck on. I use a 100 macro stop down lens. Problem with using bellows with latest lenses is you can't adjust the iris.
I get better results using my 100wr macro and a 2 times converter.
k-mount, pentax lens, slr lens
Lost x-sync port screw-on cover for K-5, can it still be used in rain without damage? LeDave Pentax K-5 6 10-02-2012 11:09 PM
Sharpness and metering problems with Bellows on the K-5 Matchete Pentax K-5 25 02-14-2012 12:31 PM
Can a Teleconverter be used with a zoom lens? Vantage-Point Pentax SLR Lens Discussion 10 11-28-2011 07:00 AM
What lenses can be used with K-5? lebjohnson Pentax SLR Lens Discussion 8 06-24-2011 06:48 PM
Which lenses can be used with a TC? Noisychip Pentax SLR Lens Discussion 6 05-07-2008 05:04 AM
All times are GMT -7. The time now is 03:21 AM. | See also: NikonForums.com, part of our network of photo forums!
