02-14-2008, 06:05 PM   #1
best alternatives to DA* 50-135 ?
If I want a fast zoom for sports (indoor basketball, baseball, maybe soccer) what are the good alternatives to the DA*50-135? should I just save my money and pay the piper?
02-14-2008, 06:09 PM   #2
and
possibly tamron 70-200 f2.8 and further down the line sigma 70-200 f2.8 hsm. both with more reach
02-14-2008, 06:40 PM   #3
I have the 50-135. It's an awesome lens.
02-14-2008, 10:22 PM   #4
jgredline's Avatar
QuoteOriginally posted by kmccanta Quote
Pay the piper...In addition, it works great with the Tamron 1.4tc and will give you nearly 200mm of fast, sharp shooting..
02-14-2008, 10:26 PM   #5
Gooshin's Avatar
for 750 dollars (B&H), you will not get a better lens in its class
unless you are dying for 200mm coverage, then you can either choose a tamron or sigma in, but you dont get weather sealing, and they wont cost you any less.
02-14-2008, 10:28 PM   #6
Buy this lens along with a TC, and you should be good to go.
02-14-2008, 10:40 PM   #7
I'm also thinking of buying this lens until Sigma announced the 50-150mm and 70-200 HSM. I will wait and see if Sigma's HSM will focus faster then Pentax SDM
02-14-2008, 10:42 PM   #8
Gooshin's Avatar
QuoteOriginally posted by Paul Quote
whats the point, the AF sensor is shit.... even in the K20D
02-15-2008, 10:18 AM   #9
CWL
If weight and size is a factor for you, definely go for the 50-135. I got mine two days ago. I can fit it in my compact camera bag and carry it as daily use + event/concert/sport. 70-200 will have the longer reach, but I won't use it that frequently due to the size/weight. But this is just me.
02-15-2008, 10:36 AM   #10
RBellavance's Avatar
The limiting factor is not the AF drive (be it screw-driven or SDM/HSM), but the way AF system works.
02-15-2008, 10:38 AM   #11
Weather sealing
If you want weather sealing there are no alternatives. If you don't need the weather sealing I'd get the Pentax K 135 F2.5, one of my favoritest lenses,
and take the money you'd save and get another lens or two.
NaCl(weather sealing is the main reason I'm lusting after this lens)H2O
02-15-2008, 11:09 AM   #12
[QUOTE=NaClH2O;177897]If you want weather sealing there are no alternatives. If you don't need the weather sealing I'd get the Pentax K 135 F2.5, one of my favoritest lenses,
Do you mind if I call you brine? Anyway, I couldnt find the K135/2.5, but I have the M135/3.5. smaller, almost as good.
My issue is for shot of my son playing sports, I miss a lot with my prime kit, because I'm framed for 1st base, not third etc... or I would like to reach the far side of the court as well as the near.
For the money, I could opt for a second body as well, but I think I would prefer more glass.
02-15-2008, 11:59 AM   #13
jgredline's Avatar
Frankly, it's worth buying simply because it looks cool....But the fact that it is a fast, sharp lens is bonus...or is it the other way around.
02-16-2008, 01:41 PM   #14
I've been pondering the same issue as the OP. I like doing a lot of portraits and I wanted to get a fast zoom because it'd take up less room than a set of primes, and would be more flexible for just a little-less sharpness. However, the 50-135 is so far out of my price range it'd might as well not exist, especially as I'm (just about) lusting for a K20. However, I've been having a lousy run of luck with tracking down a inexpensive zoom. I've haunted Ebay & KEH for a while before a Tokina 70-200mm AT-X 2.8 showed up and I won it for just under $250. Unfortunately, the interior zoom element had some bad hazing and I had to return it, which is just as well considering how freakin' heavy that thing was-I have tendonitis in both hands, so I don't have a lot of arm strength, and I prefer to hand-hold my shots (a lot of my shots are spur-of-the-moment, so even a monopod would be klutzy at best, and I don't think the string trick would help since my problem stems from supporting the weight). Because of the weight of the Tokina, I started looking at slightly slower lenses, such as the lengendary Vivitar Series 1 70-210mm & the Tamron 19AH. I had a couple of Series 1 sniped out from underneath me before I won a 19AH on Ebay, but then the seller found hazing on it just as he was packing it and offered me a refund. Later that day, I found another 19AH on B&H Photo for $140 used (rated as an 8 condition wise, no hood ,rear cap, nor case) and snapped it up and it just arrived last night. Unfortunately, I've found it almost as heavy as the Tokina 70-200mm F2.8 and my initial test shots appear to have some fogginess to them, even without a UV filter. I spend several minutes looking through the lens before I spotted what appeared to be something like a bunch of very tiny bubbles inside the lens-kinda like ginger ale bubbles. I'm in the middle of taking some test shots using a tripod to make sure the fuzziness simply isn't motion blur on my end and comparing them to my Pentax DA 50-200mm, which I know has no problems. If the 19AH is also bad & I return it, I'm not sure what else to do at this point. I really can't afford more than $300 for lenses at this point (impending engine work on car), but I need something lighter than what I have, and the DA 50-200mm simply isn't fast enough for some of the shots I want to take. I could probably get a series of relatively-fast primes (I already have a 50mm 1.4, so I'd probably need a 85mm, 100mm, 135mm, and 200mm) for that amount total, but then I'd have to be picking between which half-dozen lenses to carry with me at any given point instead of just a few. And I'd lose some flexibility and convience due to having to change lenses more often. Erg!
02-16-2008, 02:07 PM   #15
Shashinki's Avatar
The Sigma 50-150 f2.8 HSM is soon to be available in K-mount. Why not have a look on that one if the 50-135mm is too expensive?
It doesn't have weather-sealing, but it gives you a little more reach and it does pretty good in tests. Size and weight are also close to the 50-135. Much better than 70-200 f2.8 in that department.
*edit* Just noticed that the Sigma isnt priced less than the 50-135 at B&H, but if you go in a store you should be able to haggle it down a fair bit more...*edit*
alternatives, k-mount, pentax lens, slr lens
Some alternatives to Sanyo Eneloop? DavoMrMac Pentax Camera and Field Accessories 28 02-01-2010 03:47 AM
Supertelephoto Alternatives jstevewhite Pentax SLR Lens Discussion 24 07-23-2009 02:27 AM
Alternatives to the 50-135? heatherslightbox Pentax SLR Lens Discussion 24 08-01-2008 12:55 PM
alternatives to a ... wrxwheelman Pentax SLR Lens Discussion 16 04-30-2008 04:22 PM
Less expensive quality alternatives to 31? heatherslightbox Pentax SLR Lens Discussion 18 04-04-2008 09:52 PM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
