Originally posted by JinDesu I'm also having trouble making the camera save the lens firmware onto the SD card. I got a k-30 and I have it open to the debug menu. Any thoughts, advice?
Nevermind, found the issue:
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250555-resurrect...ml#post2756940
Also, looking at the k-30 debug menu, the R/W feature only shows 00 when reading the addresses. I'm going to wildly assume that this means the k-30 just doesn't have the ability to make the 16-50 convert. And same with the k-3. Just checked on that too.
I'm not sure what didn't work for the K3, so I grabbed one of my K5 cameras and it went without a hitch.
I have two DA* 16-50 lenses and their # are 9045389 and 9045481. They are only 92 apart from one another, so they probably came from the same batch.
In the LENSEEP.LNS, 00 through 05 columns are identical, 0E through 0F are too.
06 through OD change, so the LENSEEP.LNS is specific to each lens.
