12-27-2012, 05:43 PM   #31
clover's Avatar
QuoteOriginally posted by alanebs Quote
eagerly waiting for codes to disable sdm in 50-135... thank you for sharing! or is the code for 16-50 same as the codes for 50-135?
The lens file is completly different, from 16-50, to 50-135mm, but you can find where there is some similar code to change.
Unfortunatly , for the 60-250mm, it is different, but I only try one way.
12-27-2012, 05:46 PM   #32
clover's Avatar
QuoteOriginally posted by Alizarine Quote
I thought long and hard if this could be done... now it is. Thanks to whoever did this contribution it is SO VERY HELPFUL!!
I am only the last "link" of this process. The hader thing was already done, but I am the only one who give the way to do it with the DSLR without using NotePad++ (it isnot really hard as long as you understand how it works)
12-27-2012, 05:47 PM   #33
clover's Avatar
QuoteOriginally posted by Shinwar Quote
But how can it works on K-5?
We cannot enter a full development menu through PKTether
I gave you a way to try, but it will takes time and I am not sure it will works...(1000 differents MODSET files to create)
12-27-2012, 05:50 PM   #34
clover's Avatar
QuoteOriginally posted by aurele Quote
exactly what i think !
We should ask the tech guy to see if you can adjust front/back focus by the same method ?
Front and Back Focus are very hard to adjust, it is useful if you have a K10d, for younger DSLR, most of the time, the regular adjust is enought. The hardest thing is that adjusting Front and Back focus is specific for a unique couple of DSLR and Lens.
12-27-2012, 05:52 PM   #35
clover's Avatar
I hope admins put this on sticky
I do not know what could lead admins to put it on sticky, I am not sure the article is published in the right section.
12-27-2012, 07:57 PM   #36
QuoteOriginally posted by clover Quote
No,Modset.xxx cannot work on Pentax K-5
There is a rumor that it shoud be xxnnnnn.505. I tried and failed
but the extension should be 505.
12-27-2012, 07:57 PM   #37
MegaPower's Avatar
i got it work on my *16-50.
0:24 > K-x + DA*16-50
1:15 > K-30 + DA*16-50
12-27-2012, 10:09 PM   #38
VisualDarkness's Avatar
Is it faster with screwdrive? I think it looks like that's the case.
12-28-2012, 01:11 AM   #39
Thanks for posting that video, MegaPower!
12-28-2012, 01:50 AM   #40
clover's Avatar
QuoteOriginally posted by VisualDarkness Quote
My opinion is that it is more "brutal" but also more hésitating, So finally, it is not really faster
12-28-2012, 03:14 AM   #41
aurele's Avatar
which is not really difficult considering the speed of SDM !
for me it seems definitely faster than SMD but also more precise.
12-28-2012, 03:35 AM   #42
clover's Avatar
it is more "sacadé" more jerky. ( using AF-C, you can much more fell it)
The smooth of the SDM is not only bad.
12-29-2012, 10:20 AM   #43
thibs's Avatar
Merci Clover
BTW, I wonder what else could be tweaked with most other lenses, toying with the EEPROM.
12-29-2012, 11:11 AM   #44
clover's Avatar
One idea, is that you may change the registered focal length, as far as I know, using a converter do not change for the DSLR , the final length.
So, it may be interesting to change the focal lenght of a 300mm DA f/:4 with a converter x1.5, so the stabilization may be more efficience. Also, for this example, it will help to use converter and keep using the AF
12-30-2012, 02:22 AM   #45
thibs's Avatar
Indeed. It could also be used to change the lens ID
autofocus, body, camera, card, codes, computer, da*, da* 16-50mm, deactivate, deactivate sdm, debug, drive, f/2.8, k-mount, k100d, lens, lenses, memory, menu, mode, page, pentax lens, rows, screw, sdm, slr lens, thanks, time
For Sale - Sold: Pentax DA* 16-50mm f/2.8 SDM $750 OBO noahpurdy Sold Items 3 08-22-2012 09:22 AM
For Sale - Sold: Pentax SMC DA* 16-50mm f/2.8 ED AL IF SDM pentaman Sold Items 5 03-01-2012 05:10 PM
For Sale - Sold: (Price Reduced) MINTY Pentax-DA* 16-50mm f/2.8 ED AL (IF) SDM Lens Boxed hzhao1964 Sold Items 3 02-11-2012 08:28 AM
For Sale - Sold: SCM Pentax 16-50mm f/2.8 DA* SDM (US) Green Chile Sold Items 3 09-20-2010 10:43 AM
All times are GMT -7. The time now is 03:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
