K100D Super - Instructions, tested as working this weekend, to enter Debug Mode.
1. Create a file named modset.459 containing the following commands, and put it on the root directory (not in any folder) of an SD card:
[DEBUG_MODE EN]
[OPEN_DEBUG_MODE]
2. With the battery door open, and whilst holding down the AE-L and INFO buttons, turn the camera on.
3. Let go of AE-L and INFO straightaway the camera powers up, and then immediately press MENU, MENU, INFO in quick succession.
If you are successful, you should see a menu consisting of entries in white block capitals on a black background. The first menu item is DEBUG MODE. You have to be pretty quick with the button presses, so if it doesn't work, switch off and try steps 2 and 3 again.
These are pretty much the same instructions as for a K100D non-super, but the non-super does not require a modset.459 file on the SD card.
