Originally posted by Atchuu Hi I've been trying to convert my DA*15-50 to screw drive without success. I am able to access the DEBUG MENU and download the LEENSEEP file to an SD card and then to my computer using notepad++ I then modified 16ea (C0 to 8 zero) under column 3. I copied this to an sd card and reloaded it but no go. I must be doing something wrong as the lens works on an older film camera in the screw drive mode.
So you were able to use the lensrom r/w menu item to STORE the file (LENSEEP.LNS) to the SD CARD and edit it.
Originally posted by Atchuu Do I have to save the LEENSEEP file in Text Documents or All Files? Do I have to name the file a specific name for the lens to recognize it?
It has to be the exact same name it started as including the extension. Put it in the root directory of the sd card. I suggest copying the original I modified file to another location and calling it original_16-50_lenseep.LNS before making your mods.
Originally posted by Atchuu After I loaded the modified file to the lens I then attempted to down load it to a formatted SD card and there wasn't anything there.
This is really strange. You used the LOAD command under the lensrom r/w menus? The load command should go through the file and then a VERIFY step. Failing verify should leave the original file in the lens.
Originally posted by Atchuu I then reloaded the original file to the lens and then downloaded it to another formatted SD card and it (original file) was there.
So I'm assuming that I'm not making the modified card correctly for the lens to accept it.
I'm using a K10 as used by Clover in his original post.
Much thanks in advance!!!
Remember that the file must be the same name. The file must be in the root directory and the file must be LOADED from the LENSROM R/W menu. (STORE puts it in the card from the lens. LOAD puts it in the lens from the card. )
We're there any error messages?
