08-31-2019, 11:16 PM   #826
Sandy Hancock's Avatar
Yep. Wrong file. Have LENSEEP.LNS now. Fingers crossed....
08-31-2019, 11:36 PM - 1 Like   #827
Lens HACKED!
I am the Napster
11-22-2019, 04:26 AM   #828
As recently I have suspected something to be wrong with my DA* 300mm F4, I decided to try this hack.
The issue I was having was I could not get a focus lock on the lens from the close end of the focus, but could from the long end.
The lens motor was not making any unusual noise and seemed to behave as always.
I of course tried fine tuning the lens first, but even at a AF fine tune the long " far : end would lock even at +10 or - 10 and all points between.
However the short " near " end would lock focus only 30-40% of the time regardless of AF point chosen in fine tune.
This all was done on my K-3.
I installed the lens on the K-5 which I also own and did the procedure to turn off the SDM.
It worked like a charm.
I then put the lens back on the K-3, and it locked almost every time from both near and far focus areas, even in low light at F4.
So this leaves me to wonder, what could be wrong with the lens if it focuses great with the SDM disabled
and does not with it enabled.
Keep in mind the near side of the lens was the issue.
Any ideas ?
Sorry if this does not seem clear.
The near end being zero - 0 and the far end infinity as a starting point .
Would there be a change in the scripting of the LNS file that could correct the lens ?
Thanks
11-22-2019, 05:33 PM   #829
UncleVanya's Avatar
QuoteOriginally posted by dewolf Quote
Any ideas ?
Thanks
I have converted several lenses with similar results. My thinking is that the sdm starts to lose torque, which results in the camera giving up before focus is achieved.
11-22-2019, 08:48 PM   #830
well that sounds very logical. I never considered age, wear and tear concerning the motor.
But I still don't understand why I get a lock at +10 to -10 using the dot tune method.
or why there is such a negligible difference between shots when I shoot each point that its simply hard to tell.
I used to have the AF fine tune at +3, now +3 is horrid and +1 seems good lol.
But then I am using the camera's motor now, so apparently that makes a difference, as you say about the motor torque
on the SDM.
But I do love the responce and speed/accuracy of the cameras motor, even if the noise is annoying
Thanks for the heads up mate.
11-22-2019, 08:56 PM   #831
UncleVanya's Avatar
on the SDM.
I had one customer who only had problems in low light.
I can honestly only say I know it can sometimes help to convert when focus problems crop up but I can't fully explain why.
I'm glad it you were able to convert your lens and it helped the focus issues. It's always good to see these superb lenses back in action.
11-22-2019, 09:32 PM - 1 Like   #832
Thanks.
Recent tests have been done in low light due to in-climate weather outside, but tomorrow I may run the test shots again at higher speeds and lower ISO.
This lens does kick ass. I shoot with some Nokonians that spent big money on their mighty 500mm zooms, that come close, but they cant match the sharpness of this lens.
I believe I purchased this lens in 2014, and I have used it relentlessly since.
12-13-2019, 11:51 AM - 2 Likes   #833
Just purchased a cheap used K10D last night with the intent on using it to 'fix' my dead 16-50 and then double as a second body/lens combo.
Got it home, found it was updated to firmware 1.31, which from almost everything I had read, wouldn't allow access to the debug menu. Heart dropped, and spent all night and a good chunk of the morning scowering the internet for an older firware version, and a way to roll it back (which I have read is impossible if you are on 1.31. although I wasn't able to find a firmware file anyways...)
However, if you add both the debug enable command AND the debug menu open command into the txt file, it still works, and 5min later (with the use of notepad++ for quick find and replacement) had a fully working screwdrive 16-50.
So just in case someone is looking in the future, even with a fully upgraded K10D body, you can get the conversion to work.
Thanks to everyone in this thread and on the internet for all the information and support with these extremely annoying yet still high quality lenses. Especially to people like UncleVanya for being willing to do the conversion for people who can't get their hands on an older body (or comfortable with trying to do it themselves).
02-21-2020, 11:58 PM - 1 Like   #834
I give!! Throwing in the proverbial towel! I read every single page, tried every which way possible. I can not get my K10D into debug mode to save my life! 6.5 hours of my life gone!! Any help would be greatly appreciated. Currently I have ver. 1.30 on the camera. The lens is the 50-135.
2/22 Figured it out!! Updated to 1.31 and by dumb luck I did it!
06-02-2020, 06:57 PM   #835
K10D files
Trying to determine what hack files to download as K10D does not come up on the list and when I go into the Older Cameras folder it seems to be just a text file. Another issue I've run into is when I go into Debug Mode, those words show on the camera's screen but there is no menu option past Custom Settings as shown in the videos. When not holding down the menu button the screen is blank but for the words Debug Mode. I'm running 1.31. Thank you for any help anybody can provide.
Larry
06-02-2020, 06:59 PM   #836
QuoteOriginally posted by hh2Larry Quote
Larry
I'm not 100% sure but I think you need firmware 1.30 or older. Will let others chime in on that.
06-02-2020, 07:07 PM   #837
Thank you Adam, there’s a couple of messages just before mine that state it can be done. Hopefully those guys are still around.
06-02-2020, 10:00 PM   #838
UncleVanya's Avatar
Larry
Post the contents and name of the file you are using.
06-03-2020, 07:13 PM - 1 Like   #839
Larry
PM me your email and I'll send you my hack files foe the K10D on 1.31. I got my 16-50 working in minutes with them.
06-04-2020, 10:30 AM   #840
PM sent, thank you so much!
autofocus, body, camera, card, codes, computer, da*, da* 16-50mm, deactivate, deactivate sdm, debug, drive, f/2.8, k-mount, k100d, lens, lenses, memory, menu, mode, page, pentax lens, rows, screw, sdm, slr lens, thanks, time
For Sale - Sold: Pentax DA* 16-50mm f/2.8 SDM $750 OBO noahpurdy Sold Items 3 08-22-2012 09:22 AM
For Sale - Sold: Pentax SMC DA* 16-50mm f/2.8 ED AL IF SDM pentaman Sold Items 5 03-01-2012 05:10 PM
For Sale - Sold: (Price Reduced) MINTY Pentax-DA* 16-50mm f/2.8 ED AL (IF) SDM Lens Boxed hzhao1964 Sold Items 3 02-11-2012 08:28 AM
For Sale - Sold: SCM Pentax 16-50mm f/2.8 DA* SDM (US) Green Chile Sold Items 3 09-20-2010 10:43 AM
All times are GMT -7. The time now is 02:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
