Originally posted by Adam Because of the 21mm's uge DOF, I wouldn't expect FF or BF to not have much of an adverse effect on landscape photos. What you're describing sounds like a defect in the lens itself, and will probably cost you just as much to repair as it would to buy a new lens.
Adam, it is definitely a focusing issue. If you manually focus for landscapes (i.e. to the extreme end of the focusing travel), it is perfectly sharp. But if you adjust AF for a wide aperture, for a long-distance shot the AF will position it just short of the beginning of the infinity mark. It doesn't sound much, but with this lens the focusing travel is so small that it makes all the difference, even at f/8. I understand what you're saying about DOF, which is why in practice manual focusing for general shots is perfectly viable.
