02-15-2008, 02:32 PM   #1
FA77 Limited focusing ring
Has any one notice that the FA77 focusing ring is not as smooth as the FA31 Limited? I'm definitely spoiled, as I was really impressed with the focusing feel of the FA31. For example, I can easily focus with just one finger with the FA31; there's just slightly too much resistance on the FA77 to be able to do this comfortably.
02-15-2008, 03:00 PM   #2
roentarre's Avatar
Fa77 focusing ring is not bad but the travel is a bit short. I preferred manual focus from voigtlander 125mm macro which has a very smooth and beautiful manual focus.
02-15-2008, 06:00 PM   #3
wlachan's Avatar
QuoteOriginally posted by twinda1 Quote
There are 2 revisions of FA77. The front barrel of the 1st rev is supported and guided by 2 brass plates (but lean toward on side of the lens) and the focus ring can get a little heavy depends on the angles. If you mount a metal hood on it, it will get worse. The 2nd rev has 3 brass plates to spread the weight evenly and the focus ring feels lighter and will stay smooth even with a metal hood on it. However, due to the structural differences, the FA43/77 do have heavier focus ring than the FA31 (which is not a helicoil design but barrels with rollers so there is simply no resistance on the focus ring). If you bought it new recently, you have the rev2. If you bought it used (especially with the green pouch), you probably have the rev1.
02-17-2008, 07:43 AM   #4
QuoteOriginally posted by wlachan Quote
..However, due to the structural differences, the FA43/77 do have heavier focus ring than the FA31 (which is not a helicoil design but barrels with rollers so there is simply no resistance on the focus ring).
Thanks, that explains the different focusing feel. I also found an old post on the pentax mailing list where someone noticed a change in the resistance as you change the orientation of the camera. Surprisingly, mine (a newer copy) behaves the same way -- it's slight but noticeable. Definitely not a big deal.
fa31, fa77, k-mount, pentax lens, slr lens
Question about focusing ring on DA*300mm/4 dgaies Pentax SLR Lens Discussion 4 01-07-2010 10:09 PM
For Sale - Sold: Limited FA77/1.8 Black with original box and stuff TomInJax Sold Items 5 10-17-2008 03:15 PM
LBA - FA77/1.8 Limited RBellavance Pentax SLR Lens Discussion 11 09-02-2008 06:21 PM
Pentax A Lenses - Focusing Ring webb Pentax SLR Lens Discussion 0 04-28-2008 06:05 PM
Focusing ring travel. Matjazz Pentax SLR Lens Discussion 4 10-26-2006 04:41 AM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, part of our network of photo forums!
