Yup, the flange is wide enough for sure, however do you notice the tiny "drop" or if you wanna call it a lip two thirds of the way in? This is exactly the thickness of the pentax OEM m42 adapter. If that part is firm against the adapter, but the rest isnt firm against camera mount, the wobble will be there. The only question is if that difference is significant enough to cause a wobble. This is why I was hoping someone who has the lens or has used it might be able to answer the question. For reference, this is the base of a takumar
Clearly not as wide, however it is perfectly flat. When you screw it in all way the mount is firm against the camera and there is no wobble.
