12-19-2012, 05:39 PM   #1
I love to modify things.
After I learned that the only way to hold my 400mm f/2.8 A* was with a gimbal head, I have become a gimbal head fanatic. (They are pricey, but believe me, nothing works better.)
My favorite lens is the 300mm f/4.5 A*. The one without the tripod mounting ring. In my opinion, this is the best lens Pentax has ever made, maybe the best lens that anyone has ever made. One falut: no builtin tripod mounting ring.
On eBay I found a "for" Canon tripod mounting ring. Less than $7.00 and free shipping. The diameter of the Canon lens it was made to work with was close to the diameter of my 300 4.5 as far as I could tell, and for less than $7.00, what the heck.
It was too tight.
Removal of the felt lining made it closer, but still too tight.
Down to the shop. Mount a sanding drum to my drill press, turn up the speed, and VOILA--it works.
Now it IS the best lens ever.
12-19-2012, 05:45 PM   #2
Ole
Ole's Avatar
What about a picture of your setup
12-19-2012, 06:24 PM   #3
stormtech's Avatar
Talking for the FA* 300 4.5 that I own - that cheap Chinese tripod ring works almost perfectly. A bit tight where I can't totally tighten the bolt on the ring, but good enough that it will stay put for sure.
While I have never tried the A* version, I feel my FA* is very hard to beat!
12-19-2012, 07:33 PM   #4
tabl10s's Avatar
QuoteOriginally posted by pntxjack Quote
It was too tight.
Where'd you get a 400 2.8...epecially in Placerville(I'm in Sac)? It seems Pentax is all over N. CA.
12-19-2012, 09:27 PM   #5
Bob from Aus's Avatar
Which gimbal do you use? Yes I would like to see a pic of your setup with the 400. Is your rig really awkward?
12-19-2012, 10:32 PM   #6
QuoteOriginally posted by stormtech Quote
Stan--
You are probably getting used to my "mis-speaks". It is the FA* 300 4.5 that I have.
Jack
12-19-2012, 10:37 PM   #7
QuoteOriginally posted by Bob from Aus Quote
Bob-
I have the Induro GHB1. US$360 at B&H. It supports the 400 2.8 quite well, but others have suggested it is a bit scary usinng a side mount gimbal. I agree. But the others cost way too much for me.
Awkard, yes, but 13.25 pounds is going to be awkward no matter what.
Jack
12-19-2012, 10:52 PM   #8
QuoteOriginally posted by tabl10s Quote
Tabl10--
I bought it on eBay quite some time ago. It came with the 1.7x AF adapter. I don't know about you, but until this combination I always sort of snickered at the notion that a rising and falling mirror could make enough vibration to affect image quality. Now I am a believer--I try to not even breathe when making an exposure. Without the 1.7x AF adapter vibration is still a major problem, but at least I can breathe.
Before the gimbal head I had always used one of three brands of pistol grip heads. Loved 'em until I tried to molunt the 400 2.8. NO GO AT ALL.
12-19-2012, 10:55 PM   #9
Stan--
Is yours about the color of Canon lenses? Does it say "For Canon Tripod Mount Ring A (W)" on it? Cost about $6.95?
I ask because I took quite a lot of material off the inside of the one I got and the fit is still quite snug. We probably got different makes of ring.
12-19-2012, 11:50 PM   #10
stormtech's Avatar
Stan--
OK - makes a lot more sense now that you are talking about the FA* lens.
This is the one I have - bought about 1 year ago - need to check ebay more often for this stuff as it is quite a bit cheaper for the same thing usually:
Amazon.com: Opteka Tripod Collar Mount for the Canon EF 70-200mm f/4L USM, EF 300mm f/4L USM, & EF 400mm f/5.6L USM SLR Lenses: Camera & Photo
The lettering on it is just as you say above.
Notice in the pic the collar is actually almost covering the aperture ring. This seemed to be the only way to make it fit with one of the protruding edges of the inside of the collar going over the aperture ring. Just earlier tonight I tried it a little more forward - half way between the aperture ring and the focus indicator window. I found if I give it some effort it will go on this way. I do need to take away some of the felt material inside the ring, but then am concerned with marking the lens barrel. Just putting the ring on once as I explained, I think I made a mark on the metal ID tag on the lens. Not that my lens is pristine on the outside, but really would hate to make any other marks.
I will work on taking some material off the inside over the weekend.
12-20-2012, 12:31 AM   #11
tabl10s's Avatar
Tabl10--
Have you tried mirror lock-up?
01-20-2013, 05:54 PM   #12
Hi All-
Be sure to see my post of a few minutes ago re: the world's cheapest Arca-Swiss type plate.
J.
01-20-2013, 06:55 PM   #13
stormtech's Avatar
Hi All-
J.
Is there somewhere special we are supposed to look/hunt or can you post a link?
01-21-2013, 08:09 AM   #14
slip's Avatar
And Don't forget that little wee Dremel tool....a true McGuiver tool
01-21-2013, 11:14 AM   #15
gooseta's Avatar
ugh, I just missed out on the FA*300 f4.5 for $620, got outbid while asleep
canon, diameter, head, k-mount, lens, pentax lens, ring, slr lens, tripod
Nature I love nature things ohce Post Your Photos! 1 06-06-2012 08:36 AM
Can I modify to PK ... a CJZ Prakticar 1.4/50 MC ? Jean Poitiers Pentax SLR Lens Discussion 19 05-29-2012 11:45 AM
I think I've narrowed it down to 2...would love some feedback! twix23919 Pentax SLR Lens Discussion 21 03-07-2011 05:03 PM
I love my K10, should I jump to a K20? Steve Beswick Pentax DSLR Discussion 12 12-29-2010 12:59 AM
This is why I love Pentax: the little things thread mattdm Photographic Technique 5 07-04-2009 03:57 AM
All times are GMT -7. The time now is 03:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
