Originally posted by Schmidlapper I have been able to functionally test each of them and they all perform as they should.
Thanks Docrwm and vonBaloney for the suggestions. I will give the sealed container with litter a try. I won't put them in my lens bag until I get the smell off of them.
Never had much trouble with stink on lenses, it usually wipes off -- it is more bodies with leather, stuff like that. Just clean them well and get them some air is usually all it takes. If you do put them in the box, extend the focus so the barrel is fully exposed (this will often "open up" the rear to air as well), although on some lenses you may want to rotate between infinity and as close as possible so that the rear element is exposed too. Depends on the design. But if they stink you're really probably targeting rubber grips and just residual dirt in the nooks and crannies so it is probably all right on the surface...
