Originally posted by Chaim Hi everyone,
I have a K-30 and in desperate need for a fast lens. I mainly take pictures in low light conditions (in lit and not so lit rooms, in a club, in the evening etc.).
I am on a tight budget, so i checked DA35/2.4 and DA50/1.8.
50mm FL is less useful for me, but i could "swallow" it if the lens was sharp at 1.8. I understand it is not, and i would have to step it down to 2.8 to get a sharp picture.
If this is the case, this lens has no advantage over the 35/2.4, which i understand is sharp wide open.
1. Is the DA35/2.4, when wide open, really as sharp (edge-to-edge) as the DA50/1.8 stepped down to 2.8 ?
2. Is my best option really the DA35/2.4 over the DA50/1.8 ?
2. Is there an option for a faster (than f/2.4), not expensive (same price range), and preferably "normal" FL lens?
BTW, I decided not to go for lenses that would not allow me to AF (such as Manual lenses or old models).
Any answer will be much appriciated. Thanks.
I find the 35mm f/2.4 an amazing lens. It's actually my go to lens for a dark venue. However, if it's very dark, then your autofocus system is going to be the limiting factor. The 50mm may be to long for an indoor shot, unless it's an large venue.
I use tricks occasionally to get the auto-focus to work. I shot a Cosmic Bowling event recently and brought glow neckless so I could put it on all paticipants. Add to the fun and allowed me to have enough contrast when it was super dark.
For me, it's a balancing act, you need to consider depth of field, ISO, shutter speed, focusing and amount of light (ambient vs flash). Full manual is the only way to go for a dark venue. A flash will also give you another level of sharpness by freezing the subject more. I also take into account how much I can raise the image in post processing. I may shoot on the darker side because I can raise the shutter speed another stop and raise the light in post.
I like primes and constant f/stop lenses. I don't think you can go wrong with the DA 35/2.4. I have a A 50/1.7 and it's also an amazing lens. Waiting for my DA 50/1.8 which should be here in a week. I'm planning on using it in larger indoor venue where the 35mm would be to short.
Shoot raw, full manual, use a flash with some light modifiers if possible, post process.
