01-14-2013, 12:54 PM   #31
Shanti's Avatar
QuoteOriginally posted by borno Quote
Looking at the images on my laptop, I think they aren't as sharp as they should be. I would exchange it if you can, or you probably will not be happy with it. They do make dud's, I don't think many companies check every lens, I got a bad FA*300mm f2.8 and they wouldn't fix it so exchange it if you can. I loved the DA300mm and the sharpness is excellent if you have a good one. Using a long lens takes some practice too, use higher iso's, hold it steady, even a monopod and SR is a big help. I didn't go much below iso 400 especially with animals.
Hi looked at your gallery shots..good timing on alot of the BIF ones..that's what I plan to do with the lens when it gets lighter here...are you sharpening them alot in PS or? did you see the latest cat ones in my dropbox? I think at F9 they should be sharper/more DOF at 5m away from the subject,or is that normal? after using 4/3 for so long at 300mm/600effective seems more DOF with Oly,but I know the smaller sensor size helps it..
01-14-2013, 03:27 PM   #32
borno's Avatar
Those last ones look pretty good, I think. I would post some of mine, but I'm not exactly sure which ones are with the DA300, as I had the sigma 100-300mm f4 (very good also) and I don't have the pentax software to check the exif on my new computer. I missed the 300mm f4, and just got a deal on a used 300mm f4 for my canon and am quite pleased with it. Very similar in sharpness and nice close focus too, like the pentax.
For sharpening, I usually stick with the capture one default with sometimes set the radius up a tad like from .8 to 1.0. nothing fancy.
01-14-2013, 03:39 PM   #33
borno's Avatar
I found a 100% crop with the 1.7x afa and the k20d if it helps at f8 (I'm guessing f5 on the lens?)
01-14-2013, 05:24 PM   #34
QuoteOriginally posted by Shanti Quote
...only had camera for 2 weeks now as switched from OLY for more resolution,so of course I don't know the K5II so well yet.....
You made my point.
Cheers..M
01-14-2013, 09:00 PM   #35
Shanti's Avatar
nice borno..you focused on the eye yes? and F5/8 you got more DOF than I got at F9... I shot some swans(1/250 F8,monopod) at maybe same distance and not as sharp, so I really wonder if its the lens, cause camera shake will look different ...
01-15-2013, 03:44 AM   #36
borno's Avatar
The AF area is pretty big and probably covered half the bird at the distance I was at. I used a monopod with SR on and took plenty of shots to be sure to get sharp ones and in focus. I don't think you will find more DOF with any lens at a particular aperture and focal length. This is still a bit of a crop. They love it to get a Walleye (good eatin')
01-15-2013, 06:26 AM   #37
Shanti's Avatar
Great shot there..maybe he's looking at you as his next meal Buzzards are the biggest birds here in the wild, do miss seeing eagles..alot in N. Calif. when I lived there. You have SR on with monopod? I thought that was not good or is it only on a tripod?
da300, k-mount, pentax lens, slr lens
Can't decide between DA 55-300 and FA 100-300 amorificus Pentax SLR Lens Discussion 6 04-27-2012 10:35 PM
Nature Making friends with my new DA 300 Dice Post Your Photos! 9 04-03-2012 08:01 AM
Got a K5 for $950! Can't believe it! Can I get the sensor stain fixed? crossover37 Pentax K-5 32 05-13-2011 05:04 PM
[K-x]How can I get a sharper picture Pak Troubleshooting and Beginner Help 21 09-07-2010 03:58 PM
All times are GMT -7. The time now is 02:54 PM. | See also: NikonForums.com, part of our network of photo forums!
