Originally posted by KungPOW What mode are you using? The A lenses need either TA or M.
Do you have the aperture ring set to "A"? If you want to use the ring, you need to have the camera in M mode only. In M mode, you can meter by hitting the AE-L button. In wich case, you need to set the custom settings "allow use of aperture ring" and change the AE-L button to TV shift.
Does the lens stop down when you DOF preview?
Eric.
Eric, dial set to AV mode and aperture to "A". I use a number of Pentax "A" and "M" lenses and none of them have ever done this.
"allow use of aperture ring" was one of the first things I did when I got the camera.
Does not stop down on DOF preview
What puzzles me is, if it is the lens why does it work on the K10D?
Heinrich
