Now that I am a Takumar smatterer, I would like to disassemble and regrease some of my non-Takumars too, particularly my Helios 44M, but also looking at the Industar 50-2 and the 61 L/Z.
I have disassembled the Helios, but the principle appears to be quite different from the Takumars I've seen. I had first looked at
this instructional suggested by colleague
stevebrot, and then took a dab at the lens myself. The symptoms were that it had a slightly stiff spot in the focusing ring, and also slight play. I did not manage to repair any of these, but I think I have reassembled it wrong.
First thing I did wrong, was unscrew the 3 screws that were holding the optical group and the main helicoid together. Bad move, because unlike Takumars, the tabs holding the optical block in the grooves are not locked by anything, and the optical group simply slid out. Before I could understand anything, I also moved the helicoid back and forth, losing notion of infinity focus.
Next thing I did, I unscrewed the small set screws (all 6 of them) that were holding the DOF ring and the focusing ring mounted on the brass part inside. I realized that the set screws should enter some special holes left in the brass, because as I missed correct entering position, the tips of the screws were simply left hanging out.
What I did to reassemble it was to place the DOF ring with the set screws in the proper holes, so now I had that as a reference. Then I connected the optical group to the helicoid, screwed that in, went outside and focused to infinity, then mounted focusing ring set at infinity, and tightened the screws. That sounds OK, but it isn't, actually, because as I said, the screws are not completely in (the infinity that I found did not coincide with the 3 holes already engraved in the brass piece).
My question is, basically, what's to be done, since I have lost all marks, I will have to assemble it the way they did at the factory.
I realize this is hard to follow, but if anyone has worked on these lenses, maybe they can shed some light on how it's supposed to be done
