Hello,
I bought cheap (25 euro) a SMC-A 50mm F1.7, but there is a problem, 2 spheres are missing.
The major problem is that little sphere that makes the A contact is missing, so it doesn't work in A mode.
Another one is the sphere that makes the clicks in the aperture ring is also missing, but that one is more or less irrelevant. Otherwise the lens in in good shape, the glass is very clean and the aperture blades are snappy.
I wonder if any of the nice folks here in forum as some advice to fix this problems.
Does anyone know some sphere of the same diameter as the missing that could be used, or some other workaround to fix the A contact?
Thanks in advance.
