01-22-2013, 04:53 AM   #16
I thin I ll save.
But it is impossible until later in summer as I have few trips planned.
Consensus- to save for a better lens
But what to get for a temporary shoot ? One of those mentioned above ?
Let's say to spend 100 150 gbp for temporary one and sell it after. Which would be easier to source in uk (or in canada, as I can buy it to be sent to friend of mine )and sell without much hassle ?
01-22-2013, 05:06 AM   #17
Hmmm 599 - cashback 50
01-22-2013, 05:12 AM   #18
One thing... can it just to be too long for me ? I d probably live with anything up to 300 ?
01-22-2013, 08:07 PM   #19
Since I have had heavy search through different choices I have discovered (sorry for changing opinions every time) interesting option:
pentax da 12-24 (which is expensive so similar Tokina can do the job) which would be great for landscapes and interior shooting.
How do you think, if I keep 30 mm sigma then add 12-24 , would it be step in the right direction, or I need bigger zooom first and only then adding wide angle ?
Or 12-24 is too close to 30 mm prime ?
01-22-2013, 08:36 PM   #20
p38arover's Avatar
QuoteOriginally posted by voxxonline Quote
What about aforementioned F 20 -210 F4 5.6 Pentax... ?
It has a positive feedback from owners
I can't find that lens. Can you point us to a review?
Or did you mean 70-210? If the latter, https://www.pentaxforums.com/lensreviews/Pentax-Takumar-F-70-210mm-F4-5.6-Zoom-Lens.html, I have one and have had it since 1989 when I bought it with my Pentax film camera. I like it and they can be picked up quite cheaply.
01-22-2013, 08:41 PM   #21
My bad- it is 70 210
01-22-2013, 10:21 PM   #22
cmohr's Avatar
Sounds like you want a long lens, and a wide angle??? So, In one lens, the Pentax WR 18-135 would be great. or for a two lens kit , get a Pentax 55-300 its a sharp lens for not a lot of cash, and then pick-up a used 18-50 kit lens secondhand ( real cheap).. Oh, If you can, I'd keep that 30/1.4 Its a star for the money.
01-23-2013, 12:25 AM   #23
Probably I cannot have a bit of everything
Somehow I like the 12 24, but how will it perform as "everyday" lens... ?
WR 18 135 is good but if I can do 12 24 I ll go for it .
All in all I ll buy cheap vintage for a moment and save for one of suggested .
01-23-2013, 03:49 AM   #24
Hi Ivan,
I will keep the Sigma 30 f1.4 for all purpose low light shots.
Depending on what you intend to use it for, Pentax 55-300 is a good buy if you need the reach in reasonable light.
If you need a longer lens for portrait shots of your daughter, go for a Sigma 50 f1.4 (sharp wide open) or FA 77 (which i have both) or 50-135 f2.8 zoom.
All the best.
01-23-2013, 10:35 PM   #25
How in theory prime 77 adds up to 30 mm sigma ?
I am trying to figure out focal length I need- most probably it is a lens up to 135 (because wr 18 135 covers this range) and I do not want to stretch further. It is decided for sure.
So having in theory wr 18 135 as a back up plan I can think about alternatives- and primes as well. The only thing I am not sure will making combo of 2 primes give me a better choice in photography or not.
I gave up idea having all in 1 swiss knife and should lean towards more specific lenses.
01-24-2013, 12:01 AM   #26
MegaPower's Avatar
QuoteOriginally posted by gooseta Quote
Keep the sigma, it's hardly worth chips now that the new 35mm has come out and it has been discontinued. Use what you have, it's a great lens and has absolutely stunning center sharpness right from f1.4 (Sigma AF 30mm f/1.4 EX DC HSM - Review / Test Report - Analysis), sure the corners are mush, but it's a versatile lens and it's good to have primes. I find my Tamron 70-200 too short for wildlife, I'd recommend a telephoto prime or bigma
Where did it mention the 30/1.4 has been discountinued?
I don't see it, even the Sigma official website is still selling them.
01-24-2013, 08:41 AM   #27
creampuff's Avatar
Keep the Sigma 30mm f/1.4. The angle of view is versatile for a wide range of subjects and the large maximum aperture makes it ideal for low light situations. If you need a tele, even the DA 50-200mm WR or DA/DAL 55-300mm are decent tele zooms if you're on a limited budget.
01-24-2013, 09:01 AM   #28
Your biggest benefit of going with primes over zooms is that a prime lens tends to be faster than a zoom.
I would most definitely hang on to the 30mm 1.4 for now. If you find that you are absolutely never using it, then sell it and put the funds towards a different lens that will get more use. However, in my own experiences (YMMV), I always have a need for faster glass. A 30/1.4 is perfect for indoor shots when with family and friends. As far as the prime 77 goes, If you are talking about the FA 77/1.8, it is an awesome lens. I haven't had the good graces to use one myself, but if you dig around on the forums you can find a lens club devoted to the FA limiteds. The 77/1.8 produces some wonderful images, bokeh and color rendering.
If you want to go the route of 2 primes, something around 35mm is great for indoor shots (Like that 30mm 1.4 you have!), and then something a little bit longer for outdoors and/or headshots. If you can afford it, the 77/1.8 would be a wonderful choice. A slightly cheaper, also great choice, is the DA 70/2.4.
01-24-2013, 09:19 AM   #29
Thank you !
So second step is primes between 70 to 80 mm to choose.
Good. Now I can concentrate on that specific interval and see variants.
01-24-2013, 09:27 AM   #30
The only reason I said 35ish and then 70-80 is because that gives you a little more variance in length. You could also go with 35 and then a 50, but those will be a bit closer together. Some other affordable options are the DA-L 35/2.4, DA 50/1.8, a used copy of the FA 50/1.4 or 50/1.7. If you keep the 30mm 1.4 that you have, then you can focus on the longer options. DA 50/1.8, FA 50/1.4 or 1.7, DA 70/2.4, FA 77/1.8 (Most expensive out of all these options). Or if you really want to blow a chunk of cash, the FA* 85/1.4. It's a massive lens and fairly rare,but I've heard its phenomonal. I've seen it sell anywhere from $900 up to $1400.
k-mount, lens, love, mm, money, pentax lens, sigma, slr lens
What mm do set my camera to when using Tameron 500mm ?? Silverkarn Pentax SLR Lens Discussion 16 05-07-2011 11:01 PM
da 35 2,4 vs sigma 30 1,4. what to get? fikkser Pentax SLR Lens Discussion 27 11-14-2010 01:12 PM
Tokina 70-210 mm, 1:4-5.6 and Vivitar 28 mm 1:2.8 auto 049 mm. Worth getting for $30? shaolin95 Pentax SLR Lens Discussion 4 09-02-2009 07:22 AM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
