02-22-2008, 07:59 AM   #1
Community Manager
Ash's Avatar
K10D metering with FA 100/2.8 macro
Hi all.
Tried my K10D with the FA 100/2.8 macro tonight at a softball game and came out with some interesting metering problems with this particular combination. With the M 200/4 and DA 16-45, metering was just about right (perhaps slightly underexposed), but the FA 100/2.8 churned out overexposed image after overexposed image at EV 0.
Examples straight out of the camera:
Granted, the batter is reasonably well exposed, but I had the camera on multi-segment metering, AE-L not together with AF lock and even tried natural image mode to see if it would correct itself. No go - massive highlight clipping. Only when I turned EV down to -1.7 or -2.0 did exposure look right (from histogram). Anyone else experience this?
Oh, I should also say I've got the LL-60 viewfinder screen, the one that's divided in 3rds, which I'm wondering if it has an impact on metering...
02-22-2008, 08:19 AM   #2
jeffkrol's Avatar
Hi all.
(images removed)
Haven't had that problem w/ my lens and a D. The screen MAY be a problem though. The discussion regarding the LL-60 vs 80 series and "modern" lenses is a bit open to debate.
The LL-60 is very helpful for M and other non-A lenses but there were some apparent problems w/ exposure and modern lenses (see Lance post's) but no "proper" and "repeated" tests were done.
If your aperature mechanism on the 100 isn't bad then the screen may be a problem....
Revert to the orig. screen and test.....in a pinch you could take it off "A" and treat it as a "M" lens. Advantage to having an aperture ring.
02-22-2008, 08:21 AM   #3
Asahiflex's Avatar
What happens when you meter the FA 100 like the M 200? I.e. put the lens off the A position. Edit: this was already said above
02-22-2008, 08:31 AM   #4
wlachan's Avatar
The difference between 1/30s & 1/40s is really small and slight variations like this in practice is not uncommon at all.
02-22-2008, 08:39 AM   #5
Lowell Goudge's Avatar
I think the contrast ratio is beyond the capability of the sensors, and iuf you are metering multi segment, the black or dark backgrouns is influencing this too much.
you should be metering on Spot. or manually for the situation
02-22-2008, 03:42 PM   #6
Ash
Community Manager
Ash's Avatar
Points taken everyone. Thanks for the advice.
I will try Spot metering next time, then aperture ring and see if they make a difference.
Much appreciated guys.
02-25-2008, 01:20 PM   #7
Ash
Community Manager
Ash's Avatar
Can confirm, at least with my setup, that the LL-60 screen and FA 100/2.8 on A setting have a hard time metering. Once I took the lens off A, the camera metered fine. Spot metering alone did not fix the problem.
So far, I've needed to bump up EV by +0.3-0.7 with my DA 16-45 and Tammy 28-75, and they've come out with consistently good results.
Lucky I do have an aperture ring on the FA 100. I wonder if anyone has had this problem with their DFA 100/2.8?
02-25-2008, 01:48 PM   #8
creampuff's Avatar
If you're having to compensate EV with all your lenses, the culprit could be your focusing screen that's affecting the meter reading. If you're not using the A setting (using your lens like a non-A lens), the K10D has a tendency to underexpose which is why your overall exposure might be ok.
02-25-2008, 08:33 PM   #9
Try centre-weighted metering. Multi-segment just isn't accurate enough in my experience, and likely the batter is confusing it. Note the M 200 would have been running in centre-weighted mode anyways.
camera, ev, fa, image, k-mount, k10d, macro, pentax lens, slr lens
K10D metering errors Tringle WP Pentax DSLR Discussion 11 04-17-2010 11:05 PM
Metering problem on K10D? hyyz Pentax DSLR Discussion 4 03-03-2010 04:17 PM
K10D metering: different lenses annod Pentax DSLR Discussion 17 02-09-2009 05:15 PM
Exposure test: K10D and SMC-P M 100/4 Macro Canada_Rockies Pentax DSLR Discussion 2 03-04-2008 05:20 PM
K10D: Metering in other than A dhodgeh Pentax DSLR Discussion 4 12-19-2006 12:00 AM
All times are GMT -7. The time now is 08:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
