Originally posted by Nass Simple answer - I don't know and I'd really hate to misdirect you. Ask them for MTF tables, see if it's worth it? I don't want to seem patronising but be aware that at this mag it's about a lot more than just the objective. Ie stability, light source used, diffusion, light leakage, pp, software used to stack all play their part so eventhough you may buy a great objective it might not quite give you what you're hoping for unless all the other bits of your rig are top notch too...
Don't be afraid to be patronizing
I've been experimenting with 3.5x magnification with a raynox and focus stacking. I now better understand the challenges I will face.
The camera will be used in a lab, on a tripod, with a diffused continuous source of lighting. The camera itself will be on a macro rail (the stackshot rail) which can automate stacking exposures according to increments we set. Afterwards I will stack the shots in Zerene (I'll try with a PMAX first) then use the retouching tool. Then import in lightroom and PP the photo as I would any other.
That is my plan, anyway. I'm sure there will be a learning curve but I am willing to tackle it on and I have the resources to do so. Getting the experience is the fun part
But as you say I need to do the proper research and buy the right equipment to make sure I can interface everything properly, and then I can experiment.
