02-25-2008, 11:04 AM   #16
blende8's Avatar
QuoteOriginally posted by Gooshin Quote
but a lens with an aperture ring that clicks into pre-defined (and extensively tested) aperture positions would have much more credibility than a fully electronically controlled lens.
Yes, I agree.
02-25-2008, 11:27 AM   #17
blende8's Avatar
Here is a more complete row.
Quite noisy, because it is already quite dark.
Larger copy:
http://www.informatik.uni-bremen.de/foto-ag/Bilder/Vergleich-2.jpg
02-25-2008, 12:01 PM   #18
Gooshin's Avatar
cool!
definetly a difference in sizing after F4, almost like the FA is "in the middle" between the DA lines,
perhaps this is due to the 8 blades vs 9 blades?
02-25-2008, 05:26 PM   #19
no, circle of confusion is bokeh...
Sorry, but it isn't. From the same site I linked to too:
"In photography, the circle of confusion diameter limit (“CoC”) is sometimes defined as the largest blur circle that will still be perceived by the human eye as a point when viewed at a distance of 25 cm (and variations thereon)."
When was the last time you heard of someone enthusing over the pointyness of their lens' bokeh? (Well, actually, it happens all the time, except it's called "resolution" in those arguments) Bokeh and CoC are opposites: one is when the projected point of light still appears as a point of light, and the other is when the point of light doesn't appear as a point of light at all.
02-25-2008, 05:40 PM   #20
distudio's Avatar
QuoteOriginally posted by Jerry Thirsty Quote
Exactly, CoC is only used to determine theoretical DOF. CoC is generally accepted to change with capture format for the same lens since the magnification required to produce the same print size will differ. Bokeh is the Japanese name for the perceived quality of out of focus areas of the image.
02-25-2008, 06:04 PM   #21
Gooshin's Avatar
okay.. how does bokeh manifest itself, in technical terms?
02-25-2008, 07:01 PM   #22
distudio's Avatar
It's a perceived quality, it's not technically defined so no one has produced an objective method of assessment. Good bokeh to one artist maybe bad bokeh to another.
02-25-2008, 10:12 PM   #23
Rickster's Avatar
The circle size should change by the factor (√2)/2 = .707 per full stop.
02-25-2008, 10:25 PM   #24
mattdm's Avatar
QuoteOriginally posted by distudio Quote
But, there are a few objective factors: generally, neutral disks are regarded as more pleasing than dots with bright centers, which are in turn nicer than donut shapes or bright-edged circles.
02-25-2008, 10:43 PM   #25
distudio's Avatar
QuoteOriginally posted by mattdm Quote
The point is that it depends who the viewer is as to what they deem as nicer.
02-26-2008, 12:40 AM   #26
blende8's Avatar
definetly a difference in sizing after F4, almost like the A is "in the middle" between the DA lines,
I have two ideas what the cause may be,
  • it could have to do with the internal focussing of the DA*. If the focal length is only 180-190mm instead of 200mm, the circles will be smaller. The distance was about 3m, so this could be possible.
  • I have the suspicion, not sure though, that the size of the circle is also dependent of the position of the aperture within the lens.
Anybody knows more about this?
02-26-2008, 04:10 AM   #27
You've nailed it as far as I'm concerned, but I'd add that...
1.) Circle of confusion is also generally accepted to change with presentation size and format as well. The Coc used to determine DoF for a 50" print will be very different from the Coc used to determine DoF for a web image. You basically said as much ("required to produce the same print size"), but I figured it was worth clarifying.
2.) Coc will change from lens to lens, even if it doesn't seem like it should. Quality of optics, aperture blades, and a number of other factors will create a difference.
3. That point sources will bloom into larger circles when out of focus to produce bokeh is related to circle of confusion, and the whole subject is pretty difficult to grasp if you aren't accustomed to thinking about optical science.
4. I'm getting the feeling that the original poster was actually asking about bokeh, not CoC.
Will
02-26-2008, 04:20 AM   #28
...and on the subject of bokeh, judging from the test shots here, bokeh is most pleasing (to me) and most round wide open. The aperture shape becomes visible once the lens is stopped down at all, and thus at f/4 the FA looks nicer... it is wide open. 8 blades or not, wide open it looks better than the 9 blades of the DA. At 5.6, to me, the nine-bladed aperture becomes superior, which I would expect it to continue to do. How the lens holds up to diffraction, however, could change that I suppose.
I typically prefer as many blades as possible, so I was glad to see this test (I've never done one) showing that "feature" of using a slower lens wide open.
I'm remembering some old Zeiss primes I used to use when shooting 16mm motion picture film that had three-bladed irises, and man was that some nasty looking bokeh.
Will
02-26-2008, 04:54 AM   #29
amateur6's Avatar
QuoteOriginally posted by wiyum Quote
Not only that, I'm guessing the OP is sorry they asked!
A few links for anyone who wants to do further reading in a more authoritative source than Wikipedia (from shortest to longest... funny how their page titles are the inverse of their actual length):
Circle of Confusion: Optical: Glossary: Learn: Digital Photography Review <-- DP Review
Understanding Depth of Field in Photography <-- Cambridge in Colour
Digital Depth of Field <-- Bob Atkins
bokeh <-- Luminous Landscape (the article, despite the title, uses the unfortunate "boke" transliteration of "bokeh")
02-26-2008, 06:35 AM   #30
Gooshin's Avatar
i'm not talking quality!
i'm asking you how it is CREATED, what within the lens is responsible for bokeh manifestation?
circle, confusion, da, ff, k-mount, lens, pentax lens, slr lens
FA versus A 645 lenses matesa Pentax Medium Format 9 05-26-2010 04:04 PM
Old Tokina 100-300mm F4 versus newer lenses whelmed Pentax SLR Lens Discussion 10 04-12-2010 10:11 AM
Circle Of Beauty Jimbo Post Your Photos! 21 12-10-2008 04:55 PM
It has come full circle TiJean Photographic Technique 11 06-19-2008 06:03 AM
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
