02-15-2013, 09:01 AM   #1
Question about the Tokina 24-40mm F/2.8 AT-X lens
Hey all
I was wondering whether you could help a newbie (to Pentax) out?
I just bought a K-01 and decided to pick up a couple older lens to go with the 40mm XS lens that came with the camera. Of course I did not know about the KR mounts until it was too late. Within 5 minutes of using the K-01, I had a Starblitz 28mm f/2.8 stuck on with the dreaded KR pin in the focus screw problem. I managed to remove the lens with the help of a colleague that's also a photography fanatic. Phew!
Now that I am more careful, I realize this Tokina also has the same pin. From what I can tell, it's supposed to be a K mount lens for Pentax cameras. I tried searching for Tokina KR lenses and had not much luck. Can anyone help me confirm whether I can use this or should I return this lens?
With the Starblitz, I removed the pin based on a recommendation from one of the websites. I also tried removing the mount for the Tokina, but it's a lot more complex probably because its a zoom, so I don't really want to fiddle too much with it.
Thanks in advance!
02-15-2013, 11:17 AM   #2
Compare with the one that got stuck and you will see that this one is a lot bigger and rounded, the other ones are quite small and have
a sharp edge to them.
Should not be a problem.
Get an old Pentax AF camera and keep it for lens testing, I have an SF1 that I picked up for $5 for that purpose.
f/2.8, help, k-01, k-mount, kr, lens, mount, pentax lens, pin, slr lens, tokina
For Sale - Sold: Angenieux optical formula: Tokina AT-X 28-70mm f/2.6-2.8 rajubhai55 Sold Items 3 09-05-2012 06:17 PM
For Sale - Sold: Tokina AT-X Pro 28-70mm f/2.8 Angeneiux kthung Sold Items 4 05-13-2012 06:14 PM
Concert lens: Sigma 24-60mm 2.8 EX DG or Tokina AT-X 270 AF Pro II 28-70mm f/2.6-2.8 nitemare_kx Pentax SLR Lens Discussion 11 09-28-2010 11:33 PM
Tokina AT-X 24-40mm/2.8 haystack Pentax SLR Lens Discussion 3 06-14-2010 06:13 PM
All times are GMT -7. The time now is 05:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
