02-15-2013, 03:19 PM   #1
DaveHolmes's Avatar
Working Trip to London - One Lens Only
I've spent the last 2 months doing some work with a theatre company on a play.
Leave for 'that London' in the morning for just less than a week, most of which will be spent, re-building the set, rehearsing (it's ok, I'm not actually 'in' the play ) and generally working at a pretty frantic pace... Not going to have masses of time for photography but may get an afternoon...
I'm taking the K5 (it goes everywhere I do in general) but need to travel as light as possible so thinking that I need to leave a fair bit of kit at home...
I normally carry: K5, FA35 attached + FA28, FA50, D-FA100 and a Vivitar 19mm f3.8 as well as a flash and bits and bobs...
Thinking of just taking the 18-55WR lens (obviously attached to the K5) but worried about the loss of IQ and all my filters (ND's, CPL etc) are in a 49mm thread...
The plus is that it saves me space and time in a city I'm only vaugely comfortable in being fairly adaptable - when I was last there it was so busy that swapping out lenses was a bit of a chore...
Wishing I could've afforded the move to K5 without having to have sold the Tamron 17-50 right now...
02-15-2013, 03:23 PM   #2
ivanvernon's Avatar
QuoteOriginally posted by DaveHolmes Quote
Wow, I was just going to suggest the best single lens for London trip is Tamron 17-50!
02-15-2013, 03:26 PM   #3
slip's Avatar
If it was me, I would rather a 17-70mm which covers landscape, street scenes, and casual portraits.
Are you planning to buy a lens or take one of your own?
Thanks
Randy
02-15-2013, 03:26 PM   #4
DaveHolmes's Avatar
QuoteOriginally posted by ivanvernon Quote
It really would be but if I hadn't of sold it I wouldn't have the K5... Funny though, I hardly used it for months before I sold it!!
02-15-2013, 03:33 PM   #5
DaveHolmes's Avatar
QuoteOriginally posted by slip Quote
I've neither the time nor cash for a new lens right now - so it has to be one from my sig (see below & the F35-70)
I mostly use the FA35 but I don't think it'll be quite wide enough...
I could just buy an ND in a 52mm thread when I get there I suppose (I really like to use ND's to get rid of people in shots)
02-15-2013, 03:43 PM   #6
Dave, I am just looking on the Eizo at some shots today taken with the old 18~55mm while i practice using the K-01.
Do you have "loss of IQ" of that zoom compared to your other lenses with those filters on?
02-15-2013, 03:57 PM   #7
DaveHolmes's Avatar
QuoteOriginally posted by wombat2go Quote
Absolutely. I don't for a second think I have a bad copy of the 18-55WR but it simply doesn't compare to the image quality I get from the FA35, FA50 & DFA100 they're sharper have better (more increased) contrast and nicer colours... Even with filters - my most used 3 are: Massa ND32, Heliopan ND3,0 (practically black glass) & a Hoya PL-CIR
It compares slightly better against my copy of the FA28 but the 28 (my copy at least) has a pretty unique rendering and as such I only use it in certain situations (green-scapes generally)...
My 18-55 is good... It's just that my primes are better... As such I barely use it... Thinking for this trip it may be the only option though...
02-15-2013, 04:13 PM   #8
carrrlangas's Avatar
FA28 and you are done!
02-15-2013, 05:02 PM   #9
That's how it goes with zooms sometimes - you can not use one for quite a while, but then when certain situations come up you suddenly need it!
I also think the FA28 is a good option, although in your case you seem to like the IQ of you 18-55 a little better. But the FA28 is the all-around prime I'll take when I don't want something expensive or big. I think the rendering can be a bit unique as well, but in my mind there's something "special" about it (in a good way). At least it's faster than the 18-55, and can be readily used at f/3.2. Maybe you can sneak the DA35/2.4 or 18-55 in you luggage as well, just in case you have any regret.
02-15-2013, 05:51 PM   #10
For my personal tastes I found the DA-21 my most used lens while there. Based on your sig link choices I would go with the 28. The 19 might be better but I have never used it. You can see a limited some of what I shot with the 21, colbyt69 on Flickr. Many of these shots were from the Big Red bus some through glass windows.
02-15-2013, 07:11 PM   #11
Just1MoreDave's Avatar
I would go with one of the FAs. My choice is the FA 35/2 but whichever you're most comfortable with. You'll miss shots with any one choice, but the FA primes should make the shots you do take better. Low light is easier and the lenses are smaller. It's almost pocketable if you have a huge pocket. I might choose the 18-55 WR if you're likely to be out in the rain.
02-15-2013, 07:40 PM   #12
My first choice would be the 18-55. There is a lot of variety in London. I would find a single fixed focal length too limiting.
I would also take along the FA35. Those two lenses are not that much bigger than a Tamron 17-50. I think it is the overall portability, rather than the number of lenses that counts. It will be fairly dull a lot of the time in London, at this time of year, so a reasonably fast lens would be useful.
02-15-2013, 09:34 PM   #13
I would go with you fa28. Of course, if it was me I would also bring along the 50, but I never seem to be able to travel with just one lens.
02-15-2013, 09:54 PM   #14
I would suggest taking the FA 35 for the IQ and speed and get the best pictures. But surely you have enough space for the zoom. It is small and light and would be useful if it rained or for the odd wider shot.
02-15-2013, 10:14 PM   #15
QuoteOriginally posted by Allison Quote
Me too. 28mm is the ideal one-lens walkaround. And the FA28 is fine, although some people are a bit rude about it!
bit, k-mount, k5, lens, london, pentax lens, play, slr lens, time, trip to london
Need ideas for things to do on a one day trip to Napa Valley tomorrow photoleet General Talk 3 07-01-2012 11:06 AM
Only One Lens -What Would it Be ? uptheriver Pentax K-5 88 08-04-2011 11:39 PM
If only ONE portrait lens, which one? mhaws Pentax SLR Lens Discussion 99 06-30-2011 01:53 PM
A trip to London thomasjmpark Post Your Photos! 5 12-06-2007 09:44 PM
help---I only have one lens to use--- momof4 Pentax SLR Lens Discussion 4 10-31-2007 02:40 PM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
