02-15-2013, 05:19 PM   #1
slip's Avatar
One landscape lens only
I now have a sport lens (sigma 70 -200mm f2.8) and a *50 -135mm f2.8 for portraits and the odd wedding, and besides a bug lens I need only 1 really sharp landscape lens...I like the distortion effect for the odd people shot that happens a 15mm and under (hate fisheye)
I was thinking a siggy 10-20mm
Any thoughts or suggestions would be great... After a macro for this LBA has to end
Thanks
Randy
02-15-2013, 05:26 PM   #2
Digitalis's Avatar
The DA 15mm f/4 ASPH Limited is a good choice - it is very small people hardly notice it, so it is good for candid photography and it is well suited for landscape work. You could go for the Sigma 8-16mm f/4.5.-5.6 (lack of filters is a drawback with this lens though). Though bear in mind that just about any lens can be used for landscape photography it doesn't have to be a wide-angle, I have done landscape work with 1200mm lenses before.
02-15-2013, 05:59 PM   #3
I will wholeheartedly vouch for the DA 15mm Limited. It is a very good lens and is very compact.
02-15-2013, 06:19 PM   #4
blackcloudbrew's Avatar
The DA 12-24 f4 is a great landscape lens too. I know, the DA15 is amazing, but the 12-24mm range and rectilinear nature of this lens makes it very good through the whole FL range.
02-15-2013, 07:46 PM   #5
If its your money, a DA 12-24 would be my first choice.
If its my money, a Sigma 10-20 would be my first choice. Not as good, but good enough for me and a whole lot cheaper.
The DA15 also has a lot of appeal, but again is a lot more money than the Sigma 10-20.
02-15-2013, 08:01 PM   #6
Digitalis's Avatar
QuoteOriginally posted by NZUnicorn Quote
Don't get me wrong the Sigma 10-20 is a good choice and it takes filters, albeit large and expensive ones and like all UWA zoom lenses it still is a pretty big lens... the DA15mm f/4 on the other hand takes small, inexpensive 49mm filters:
DA15mm f/4 ASPH Limited compared to the Sigma 8-16mm f/4.5-5.6 ASPH.
02-15-2013, 09:28 PM   #7
johnyates's Avatar
QuoteOriginally posted by slip Quote
The DA 15 is really sharp . . . in the center of the frame. However, it exhibits a pronounced curvature of field. If you like your landscape pictures sharp across the field you're better off with one of the zooms discussed above.
02-15-2013, 09:28 PM   #8
ramseybuckeye's Avatar
Listen to Digitalis, he knows lenses as well as anyone. And I'll echo the comment about landscapes do not have to be shot with wide angle lenses, I would look at this as filling in your focal length gap under 50mm.
02-15-2013, 09:40 PM   #9
I have never used the siggy or the da15, but I do like the 12-24. It is a really nice range.
02-15-2013, 09:47 PM   #10
Digitalis's Avatar
QuoteOriginally posted by johnyates Quote
A good point however if you stop the DA15 down to f/11 and use hyperfocal focusing the field curvature isn't such a problem. The Sigma UWA zoom lenses typically require thin 82mm* Polariser filters and these are considerably more expensive than the regular 49mm filters you can use on the DA15.
*The Sigma 10-20mm f/3.5 uses 82mm filters, the slower Sigma 10-20mm f/4-5.6 EX uses 77mm filters - either way they need slim polariser frames to avoid vignetting at the 10mm setting. Also the flare tolerance of the DA15mm f/4 is nothing short of remarkable, Sigma lenses on the other hand do have issues with flare, especially the 8-16mm f/4.5-5.6.
02-16-2013, 11:18 AM   #11
If I were getting just one lens for landscape, it would not be either the Sigma 10-20 or the DA 15. Those are more specialist landscape lenses. Unless you want to specialize in ultra wide angle landscape, you're better off getting a standard zoom, preferably one that starts at 16mm, like the DA 16-45 or DA* 16-50. I suspect that either of those lenses would be the best if you confine yourself to only one landscape lens. The DA 16-45 is sharp for a zoom lens and enjoys very good corner to corner resolution, with surprisingly minimal field curvature for a lens of its type. The DA* 16-50 features WR and has some better color rendering I've ever seen in a standard zoom. Only the SDM and all the other QC issues associated with the lens has prevented me from buying one.
02-16-2013, 03:31 PM   #12
Digitalis's Avatar
QuoteOriginally posted by northcoastgreg Quote
this lens has been discontinued,the Pentax 17-70mm f/4 SDM lens is what has replaced it. Besides the Pentax 16-45mm f/4 ED ASPH I had years ago the image quality wasn't much of a step up from the DA18-55mm lens
02-16-2013, 08:01 PM   #13
There are still new copies of the 16-45 available from B&H.
The 16-45 may not be a great lens, but a good copy is significantly better than the 18-55.
02-17-2013, 10:19 AM   #14
ChatMechant's Avatar
If size and weight are a concern then def the 15, but otherwise the 12-24 is one seriously amazing lens. Actually, it's not that big and heavy either. It has killer sharpness, great colors, and flare resistance. I sold mine only because I could buy a sig 10-20 AND da 55-300 for what I got for it. The sig is close enough in sharpness, but doesn't have that special something that the 12-24 has. If they ever do a WR version.....
02-17-2013, 10:25 AM   #15
tclausen's Avatar
So, let me just toss this out there: Pentax 10-17?
It's my go-to landscape lens...I find that it is orders of magnitude sharper than my 14/2.8, at about the same size. Around 10mm, it's fisheye-y (it better be, given that it's sold as such) but from about 15ish mm it's almost rectilinear (and easy to compensate for any distortion in post-processing).
If I know I go for landscapes, the 10-17 and the 31ltd are what goes with me, and none of the others.
f2.8, k-mount, landscape, landscape lens, lens, pentax lens, slr lens
Working Trip to London - One Lens Only DaveHolmes Pentax SLR Lens Discussion 29 02-21-2013 11:43 AM
Macro 2 bugs went on a lunch break, but only one was hungry (Only slightly work safe) MSL Post Your Photos! 9 06-26-2012 06:56 AM
If you could only have one lens amorificus Pentax SLR Lens Discussion 66 03-20-2012 05:57 PM
Only One Lens -What Would it Be ? uptheriver Pentax K-5 & K-5 II 88 08-04-2011 11:39 PM
If only ONE portrait lens, which one? mhaws Pentax SLR Lens Discussion 99 06-30-2011 01:53 PM
All times are GMT -7. The time now is 06:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
