02-17-2013, 07:05 PM   #1
Input On The Samyang/Rokinon/Vivitar 85mm f/1.4
For a while now I've been researching for my next lens purchase for my K-30 for the purpose of Convention shooting. I'm leaning towards getting an Samyang/Rokinon/Vivitar 85mm f1.8 as its a bright portrait lens thats good value. But what's keeping me from pulling the trigger is the lack of autofocus.
I'm not unfamiliar with Manual lense, I own a 50mm from the film days that I use to experiment with; and I'm getting to grips with the K-30's Catch-in Focus setting. But would a fast, manual lens cope with a busy setting like a convention floor? Or is better to save up and buy the equivalent 85mm Sigma or even a short Tele instead?
In case someone brings it up, I have read up the few threads about suitable Convention lenses, and I'm not 100% sold on using wide angles in doors.
Thanks ahead of time for the advice!
02-17-2013, 07:08 PM   #2
Manual focus is fine for portraits but not for action (though it's certainly usable if you're willing to try).
If you're willing to pay the premium for AF, you won't regret getting the Sigma lens. However, the vivitar lens is an absolutely superb value otherwise, so it really depends on how much you need the AF. Both lenses are reviewed in-depth on our homepage.
02-18-2013, 05:53 AM   #3
hcc
hcc's Avatar
Manual focus is fine for portraits but not for action..
I beg to disagree with Adam on that one. I shoot indoor sports (volleyball and basket ball), and I prefer to use MF. I use a CZ85mm f1.4 and I got some great short by pre-focusing the lens to a known distance and using Hi-continuous shooting. In addition, AF in indoor low light can be pretty slow and hopeless sometimes. Many reasons for wich I shoot indoor sports mostly MF.
My 5 cents...
02-18-2013, 06:55 AM   #4
I'll endorse what @hcc just said.
The old-fashioned way works fine,
just like it did in the previous millennium.
02-18-2013, 07:49 AM   #5
jeffshaddix's Avatar
QuoteOriginally posted by hcc Quote
My 5 cents...
I agree, but to Adam's credit, it takes a good deal of practice, so it's not for everyone. OP, if you're willing to put in the effort, you'll like the Samyang.
02-18-2013, 08:23 AM   #6
I am with hcc on this too. Set your apperture, pre-focus, and fire away if you are happy with lighting (and ISO)...
02-18-2013, 09:08 AM   #7
I have this lens and the images it takes are fantastic. The value of the f1.4 to manual focusing is great, as you get a very fine focal plane for manual focusing on the small DSLR viewfinder. I use 1 of 3 strategies at family gatherings:
1. shoot with flash at f4-f8.0 - results in stunningly sharp images almost every time.
2. shoot subjects at a distance (from the waist up) at f2 - f4 - Good low light capability while keeping high IQ, but at the expense of a number of shots out of focus
3. shoot subjects up close (head and shoulders) at f2.8 - f5.6 and a higher ISO - retain low light capability, slightly reduced IQ, still a number of shots out of focus
I'm just an amateur and even more so with manual focus, so take what I say with a grain of salt, but I have success with the above. I rarely shoot this lens at apertures larger than f2, as I would rarely get correct focus. The only thing about this lens I don't like is the damping on the focus, which is much stiffer than the M50 f1.7 for example, its not difficult to use, just a little annoying. Otherwise, a great budget 85mm that takes great images.
02-18-2013, 04:11 PM   #8
My prevailing concern I guess is I don't want to keep my subject waiting as I'm playing with my SLR settings to make up for an aperture ring and manual focus. It sounds as though I'll need to do a greater deal of test shots on the day to know our I'll need to set it up.
Since you touched on it, Gareth.Ig. Would an external flash help this lens in low light conditions?
02-18-2013, 05:02 PM   #9
The lens is auto-aperture, so that shouldn't be a problem. Manual focus definitely requires fiddling around though.
Regarding an external flash, if I had to choose between a lens and an external flash, I would go with the flash - it makes all your lens better and its amazing how much sharper your photos will look when you are using a good flash.
02-18-2013, 05:24 PM   #10
Most "portrait lenses" have a pretty long throw, which is good for precision but not for speed. Manual focus can certainly be used for action, but some lenses are more appropriate than others. Don't have this lens but also have been thinking about it. How long is the focus throw? I have an old Takumar 85/1.9 and I certainly wouldn't want to use that for anything fast moving -- very long throw.
02-18-2013, 05:29 PM   #11
robtcorl's Avatar
Just checked mine, I'd guess about 165-170 degrees end to end.
02-20-2013, 05:56 AM   #12
Lowell Goudge's Avatar
When you consider focus throw, and shooting action with MF lenses there are a few things to consider.
First of all, your position, if you can be positioned that the action is moving across your field of view focus throw is removed from the equation because you are panning, if they are rushing towards you it is much harder to track , i agree MF can be difficult, but even then, divide the focus throw into sections. The range from MFD to let's say 20 feet is more than the distance from 20 feet to infinity. So when shooting action try not to work really close, which with an 85 should be good any way.
Second, per plan your shooting, when you take a shot don't just leave the lens where it is, but mentally think where the action is going and. Move the focus collar, even if you are not looking through the viewfinder to more or less track the action. Kind of a manual prefocus. Tis way you should be, with practice, close to correct focus all the time.
Third, focus on one subject, mentally at a time. No you can't just jump around swapping random shots, you need to concentrate on where the subject you want is going, and really anticipate the shots you take. This will allow you to get a lot more keepers with MF. Remember sports photographers have been doing this for years, long before both AF and digital, and the shots still came, it is possible, but it takes practice.
What I have outlined above will also improve the quality of your shots using an AF lens
02-20-2013, 03:55 PM   #13
Great lens but maybe not for this use
I'm using this lens (the vivitar, only because of a good deal) on a K-01 and have been very impressed. I posted three shots in this thread that demonstrate how well it works with this camera. These mostly look like very well lit shots, but the gym was quite dim. In fact the amplification that the K-01 does in live view allowed me to take shots where I wouldn't have been able to focus with a non-live view camera, and focus peaking helped a great deal. Add the scaling ISO and it works great. You might add a A50/1.7 to get a slightly wider view, that 85 comes out to a 127.5 which will keep you a good distance from the action. The third photo, the girl with the silly hat, was done standing about 10-15 feet away. At parties I've been using my 16-45. I havent been happy with the speed/ISO tradeoff, Id love to get the 17-50(?) 2.8 but it's a bit pricey for me. But in the party setting I find a zoom with a wide end very nice, and great for capturing the scenes and people. That makes me wonder if the 85 is too long. I took my 50 1.7 and the 16-45 to a recent show (mini maker faire) and found the 50 too close, that 75 effective gets a small part of a booth. The 16-45 while lower IQ (lens IQ and higher ISO due to it's speed) was great for the close-quarters work. So the 85 is a great lens, but maybe not for this use.
convention, k-mount, lens, pentax lens, slr lens
For Sale - Sold: Rokinon/Bell & Howell/Samyang 85mm 1.4 jasonfoxfire Sold Items 3 01-08-2013 04:11 PM
Is internal dust common in new Samyang/ Rokinon/Vivitar/Bower 85mm 1.4? causey Pentax SLR Lens Discussion 7 12-01-2012 01:05 PM
Samyang/Rokinon/Vivitar 85mm f/1.4 Sol Invictus Pentax SLR Lens Discussion 40 03-31-2012 12:28 PM
All times are GMT -7. The time now is 06:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
