02-17-2013, 08:21 PM   #1
help recommend telephoto for k10d
Hi I recentlly bought an ebay K10d with tamron 28-200mm lens, and its pretty good.
I want something longer for birdwatching shots. Can you recommend a lens probably around 400mm.
I have seen a sigma 135-400 which seemed reasonable.
thanks for any suggestions
02-17-2013, 08:30 PM   #2
Ari
Ari's Avatar
In terms of price, that's a pretty good lens. Of course, you can always look at getting a longer Sigma - they show up from time to time in the marketplace. And, if you want to get crazy (and I kind of want this for some inexplicable reason) there's always our overlord's newest telephoto entry:Pentax DA 560mm f/5.6 ED AW Lens 22180 B&H Photo Video And hey! The AF motor works with your k10! Always nice to dream
02-17-2013, 11:53 PM   #3
calsan's Avatar
Without a big budget, it may be worth sticking to 300mm.
on APS K10d:
200mm = 8.2 degrees diagonal
250mm = 6.6
300mm = 5.5
400mm = 4.1
500mm = 3.3
So, yes there some difference...
BUT is it enough to worry about?
The k10d isn't the fastest in terms of ISO, or focus speed, so it gets harder to get good shots beyond 200mm unless there's good light.
There's also the consideration of how sharp the lens is.
The 55-300 pentax is very sharp and as small as a can of soft drink, so it's easy to hand hold, pan flying birds and carry to where the birds are.
I would say the sharpness easily makes up for the 'short' focal length of 300mm.
Similarly, I think people with a bit more money have found that the DA*300 is better than longer lenses in terms of actual detail in the end image.
You could also have a look and see if there's anyone selling an old manual focus 300 f/4. Mostly you end up manual focusing because the birds are either flying or surrounded by twigs, so the money you save on auto focus, you gain in speed and sharpness of getting a decent, but old lens.
02-20-2013, 03:44 PM   #4
I appreciate your responding.
I will keep an eye out for the lenses mentioned. I have to admit Im still learning the technical side of the slr world, so theres a learning curve there.
thanks again.
02-21-2013, 09:22 AM   #5
reeftool's Avatar
I have a K300/4 which does an excellent job. It's manual focus but anything of high quality in AF is going to cost some $$$. These lenses can be found for under $300 in decent condition. Mine works very well with a Pentax 2X rear converter-A that I own. For birds, I would consider 300mm a minimum length. The DA *300 would be an excellent choice if you have the cash. You might want to consider one of the Sigma long zooms. All of these are going to run $1000 or more. Of course , the ultimate birding lens for Pentax would be the new 560mm which sells for about the same price as a late model used car.
02-21-2013, 09:53 AM   #6
8540tomg's Avatar
I'm with reeftool re the K 300/4. It has CA and PF issues but can deliver some great images in the right conditions. It was my goto birding lens until I got the Pentax M 400/5.6. There is a world of difference between 300 and 400mm when it comes to birding. Using manual telephoto lenses will require a lot of time and effort to get good results. Be prepared for a lot of initial failures if you go this route. There are excellent reviews on both of these optics in the lens review area.
Tom G
k-mount, k10d, lens, pentax lens, slr lens
Help a newbie out. Need a telephoto lens for K-2000 bart4casey Pentax SLR Lens Discussion 7 01-17-2012 01:41 PM
Please help to recommend a good light tent for jewelry photography raider Pentax Camera and Field Accessories 9 04-09-2010 12:20 AM
Recommend wide-angle lens for K10D Green_Manelishi Pentax SLR Lens Discussion 12 06-05-2009 01:26 PM
Recommend a polarizer filter for K10D Green_Manelishi Pentax SLR Lens Discussion 18 06-04-2009 09:59 AM
Best macro lenses for the K10D (medium telephoto) sphinx000514 Pentax SLR Lens Discussion 16 04-30-2007 06:13 PM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
