02-18-2013, 04:33 AM   #1
Tokina SD 70-210 on a K-5 II?
Hi.
Does someone know if the Tokina SD 70-210 fits on a K-5 II?
02-18-2013, 06:19 AM   #2
i83N's Avatar
Yes if it's for K mount
02-18-2013, 06:20 AM   #3
Saxplayer1004's Avatar
Which the p/k would indicated, so you should be good.
02-18-2013, 06:23 AM   #4
Thanx. Do i need to set up the K-5 in any special way, mean softwaremode?
02-18-2013, 07:24 AM   #5
jwc77's Avatar
I had the same question...doesn't this lens have a ricoh pin that needs to be dealt with first?
02-18-2013, 07:26 AM   #6
blackcloudbrew's Avatar
If you never used an older lens with an aperture ring, you will need to go to the custom menu #27 to 'permitted.' That all.
02-18-2013, 03:02 PM   #7
If you select the "A" setting on the aperture ring, the lens will function with the thumb wheel for f stops on the camera. You need to press the little silver button and turn the ring to enter the "A" setting on the lens. Custom menu #27 " using aperture ring" allows the camera/lens to function when you select f stops other than "A" on the aperture ring of the lens.You may also need to set SR length when you turn on the camera, try using 135mm as a compromise between 70-210mm.
Have fun
k-5, k-mount, pentax lens, sd, slr lens, tokina
For Sale - Sold: Image 28/2.8, Kiron 28-210 PK/A, Tokina 75-150/3.8, Tokina 70-210 F4-5.6 PK/A, 80-200 MightyMike Sold Items 65 03-14-2013 07:19 PM
Tokina SD 28-70mm 3.5-4.5 K mount on K-5IIS moomin Pentax SLR Lens Discussion 5 02-03-2013 04:10 PM
For Sale - Sold: Pentax-A 50 1.7 + Pentax P3n + Tokina SD 70-210 pencilnink Sold Items 3 08-12-2011 11:53 PM
Tokina SD 70-210 spørgsmål sniperdog Pentax SLR Lens Discussion 2 07-10-2011 11:35 AM
All times are GMT -7. The time now is 02:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
