02-20-2013, 05:22 AM   #1
500 lens question...
My gear is currently a K5II with 18-135 WR lens.
I am currently doing equestrian photography and this setup has been well up to the job.
Now I have been asked by friends and family to do some photos of their children, portraits, natural shots outdoors etc.
This is where I need your help.
My budget is now 500 and I would like to get a lens that produces some real 'wow factor' results. Focal length I am open to suggestions, the lens just needs to have good IQ and be able to AF on the K5 II.
I would prefer new, and would buy 2 lenses within the budget if required.
I do not have a flash, so if a slightly cheaper option + a flash would be recommended then thats another option for me to look in to.
I know this is a bit of an open question, but my local camera store only had limited lenses for me to try out (Sigma 30mm & Pentax DA 50mm).
02-20-2013, 06:07 AM   #2
I would try to stay under 50mm focal length as 50mm gets a bit tight indoors.
A bit over your budget but I'd say that you can't go wrong with the Pentax FA 31mm. If that's too steep a price, check out the FA 43mm ltd. It's a bit under your budget but a stellar lens. Also check out the Pentax DA 35mm macro. I don't own one but I've heard lots of good things about the sigma 30mm F/1.4. If you are not adverse to second hand lenses do a search for the 31mm ltd, it is that good a lens, you may be able to find one in your budget range.
NaCl(lots of choices within your budget)H2O
02-20-2013, 06:11 AM   #3
Thanks you - will look at all the above options! I think the lens will be used more outdoors than indoors, but dont want to get stuck having a longer focal length for those slight occasions that I do indoor shots.
02-20-2013, 06:19 AM   #4
NitroDC's Avatar
Pentax FA 43mm f/1.9 Limited. I think you'll find the "wow" factor there.
02-20-2013, 08:30 AM   #5
Will see what prices I can find the 43mm at, and go for there!
budget, flash, k-mount, lens, lenses, option, pentax lens, slr lens
500-FTZ as optical slave question PANGU_yien Troubleshooting and Beginner Help 3 12-21-2011 07:34 PM
IQ for 150-500, 50-500, 120-400 Sigma's? saladin Pentax SLR Lens Discussion 10 07-30-2011 04:57 PM
Sigma 500 Super DG Flash Compatibility Question Taskinillusion Flashes, Lighting, and Studio 4 07-05-2008 04:59 PM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
