02-21-2013, 08:13 PM   #1
MoiVous's Avatar
Lens mount wobble (rotation) on K5
I just bought a Sigma 120-400mm lens, and noticed that when the lens is mounted the lens body rotates a little on my K5 - as if the mount was loose.
Not sure if this is the lens or the camera. Tried my Sigma 28-70mm DF (also heavy, but not like the 120-400) as well and I can feel a similar thing, but not as obvious. I haven't tried any other lenses yet. Maybe its because the 120-400 is such a heavy large diameter lens.
My old Canon T70 used to do something like this until I tightened the screws holding the bayonet on the camera body.
Could this be the same sort of problem? Has anyone else experience this? Am I being paranoid?
02-21-2013, 08:21 PM   #2
With non-WR lenses it's normal to observe a very slight wobble. The reason it isn't there with WR lenses is that the weather seal adds quite a bit of friction, which prevents the lens from moving at all.
02-22-2013, 10:40 PM   #3
MoiVous's Avatar
Thanks Adam
05-18-2013, 07:02 PM   #4
olypdd's Avatar
I noticed this as well on my new K5 IIs with the DA* 60-250 mounted. It is a larger heavier lens too. A little disconcerting.
body, camera, k-mount, k5, lens, lens mount, mount, pentax lens, sigma, slr lens
Mount rotation on 645 to K adapter Vinelander Pentax SLR Lens Discussion 5 12-28-2012 11:01 AM
Image rotation when reviewing image. Worked on K7 but not K5? crossover37 Pentax K-5 23 11-21-2012 09:32 PM
Advice on using a screw mount lens with a pin on a K5 montreal.eric Pentax SLR Lens Discussion 15 10-10-2012 10:41 PM
wobble on the last lens element of the DA 15mm nirVaan Pentax SLR Lens Discussion 2 05-07-2012 08:37 PM
How do I mount Panasonic 20mm lens on my K5? mr.sinha Pentax K-5 10 08-04-2011 07:39 AM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
