02-27-2008, 04:30 PM   #1
Lowell Goudge's Avatar
how many of each lens did pentax make?
We know there are 23 million lenses to fit the K10D, based upon ads, but how many of each version did pentax make? Anyone?
edit note, the reason for posting is to try and identify which lenses are truely rare when you wtumble across one.
02-28-2008, 12:48 AM   #2
Asahiflex's Avatar
I think the exact number of lenses of each type produced will never be known. Globally, however, we can say this about the lenses:
- The longer the lens, the rarer (for instance the F* 600mm f/4);
- The faster the lens for a given focal length, the rarer (for instance the M 35mm f/1.4 although I think there have been less than 10 of that lens sold);
- Lenses for specific needs or with uncommon focal lengths are also rare (like the K 28/3.5 shift and K 30/2.8)
- The Star and Limited series lenses are rare.
02-28-2008, 01:15 AM   #3
creampuff's Avatar
Well just trying to imagine the number of 50mm lenses alone that were produced is mind boggling enough.
02-28-2008, 06:02 AM   #4
QuoteOriginally posted by Asahiflex Quote
please take no offence here but I already guessed that.
I was hoping someone had an actual number. I can imagine like everyone else, that a 50mm F1.7 was probably produced in equal quantities to number of bodies, BUT, consider the differences in lens build and performance for example between, K, M, A, F, and FA versions, some are better than others. Some just feel better, some perform very well others not so well.
I really was hoping for some good numbers, perhaps to be added to the lens database. It also helps if you have a particular lens in mind.
For example, although I have some very good and fast modern zooms, I am looking for some very fst primes, such as a 100mm F2 and 85mm F1.8. To be honest, I have never seen either of these in a store at any price. Same goes for the 200mm F2.5.
I do a lot of low light shooting, and speed IS everything in these instances.
02-28-2008, 07:14 AM   #5
Abbazz's Avatar
I would say this figure includes all the lenses made in M42 mount, including lenses from other manufacturers.
The production numbers for Pentax screwmount lenses are availble in Gerjan van Oosten's book The Ultimate Asahi Pentax Screw Mount Guide, Uitgeverij Jansz, 1999. Don't know for K-Mount though.
Edit: I just had a look at G. van Oosten's book and for most lenses, the production numbers are stated as NA.
Cheers!
Abbazz
02-28-2008, 07:30 AM   #6
Kguru's Avatar
I have a FA43 and a DA21 that were bought new recently. Serial number 26xxx and 5xxx respectively.
Can we use these as indication of numbers produced to date?
02-28-2008, 07:33 AM   #7
Asahiflex's Avatar
None taken. But sadly, the actual produced number of certain lenses is (and will remain) unknown. So you have to base this on your own experience.
k-mount, lenses, pentax, pentax lens, slr lens
Did Pentax really make a clear lens? builttospill Pentax SLR Lens Discussion 14 09-10-2010 06:20 AM
What lens should Pentax make/remake? RonMexico Pentax SLR Lens Discussion 138 07-22-2009 06:23 AM
Will Pentax make DA version of Tokina 11-16? It's the best fast ultra-wide zoom lens. ogl Pentax News and Rumors 32 08-25-2008 09:15 AM
Does Pentax make these lens? CRD-NUT Pentax SLR Lens Discussion 7 02-16-2008 07:21 PM
Why doesn't Pentax make a camera that uses another manufactures lens mount? steffi Pentax DSLR Discussion 44 04-18-2007 08:14 AM
All times are GMT -7. The time now is 05:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
