02-25-2013, 03:51 PM   #1
Julie's Avatar
Help me guess what lens this is?
Correct answer will get a cookie!
This is just an additional lens in a lot I plan to purchase, I figure it's already worth it based on the other lenses that are included (that I was able to make out from the photos), but I can't put a finger on this one...
What I do know:
-M42 screwmount
-105mm
Most likely a prime, no-macro, I'm guessing.
Okay, so, speculate away, guys!
02-25-2013, 05:52 PM - 1 Like   #2
c.a.m's Avatar
Just to get the detectives started: My guess is a Vivitar TX or T4 interchangeable, 105mm f/2.8 or 135mm f/2.8 (or f/2.5?). The clues are the double-scaled aperture ring, the number of 'bumps' from front to rear on the focus ring, and the protruding screw or pin on the mount. You indicate that it has an M42 mount, so there would be a TX-to-M42 or T4-to-M42 adapter. The green and white scales also suggest Vivitar.
The double aperture scale (and internal mechanism) is designed to allow the lens to be compatible with different camera makers' metering systems.
I don't actually own one - just recalled reading about them when I was researching Vivitar.
02-25-2013, 06:47 PM   #3
Julie's Avatar
QuoteOriginally posted by c.a.m Quote
Wow, you're good at this.
Actually got a reply from the seller, he made a mistake and it was 135 not 105; Vivitar 135 2.5.
Thanks, problem solved!
02-25-2013, 06:50 PM   #4
Yes, this is a TX or T4 mount with M42 adapter. My gut feeling (just a feeling, don't ask me why) is that is a T4 mount, not TX.
Like you, I don't think it's a macro lens.
02-25-2013, 08:06 PM   #5
c.a.m's Avatar
QuoteOriginally posted by Julie Quote
Cookie, as in computer network or treat?
Glad to have helped. If you get the lens(es), please let us know how the Vivitar works out.
- Craig
02-25-2013, 10:29 PM   #6
Just1MoreDave's Avatar
I had one and it was at least good except for flare. It's close to the size of the K135/2.5, 6 blades, for some reason only stops down to f16, slide-out hood, 58mm filter. The adapter might give you some trouble and need modification. The T4 adapter did but I never had the TX/M42 adapter.
02-26-2013, 10:14 AM   #7
macTak's Avatar
Tokina made these TX lenses, by the way (being f2.5 means it should be a TX, not T4). They seem to be rather obscure. I have the 200mm and 24mm (version 2), both of which from my very limited testing seem like competent performers. I'd expect the same from the 135/2.5 (n.b. there was a later f2.8 version of the lens as well). I'd love to see some shots with the lens when you do get it!
k-mount, lens, pentax lens, slr lens
Misc Guess what this picture really is? charliezap Post Your Photos! 13 02-02-2012 11:03 AM
Can anyone tell me what this ring on Tamron lens is? looktime Pentax SLR Lens Discussion 5 04-07-2011 04:51 AM
is it me, or the K5..guess what..its me !!! Tommot1965 Pentax K-5 18 01-28-2011 02:35 AM
Guess what phenomenal macro lens this is jsherman999 Pentax SLR Lens Discussion 22 04-19-2008 11:12 PM
Is this what you call LBA? Help Me!!! Photodan Pentax SLR Lens Discussion 11 01-02-2007 12:47 PM
All times are GMT -7. The time now is 08:34 AM. | See also: NikonForums.com, part of our network of photo forums!
