02-26-2013, 03:53 AM   #1
Hood for SMC A 28mm F2.8
I recently purchased the smc a 28mm f2.8 lens and I need to get a lens hood for it. I want to get a metal lens hood of ebay, but I'm not sure which one to get to avoid a vignette but still do the job.
Your advice on these two options or any other option would be most appreciated.
02-26-2013, 06:35 AM   #2
boriscleto's Avatar
Any 49mm screw on lens hood should do the job, even a tele won't produce any significant vignetting on APS-C.
02-26-2013, 08:22 AM   #3
Pontax's Avatar
Go for a hood intended for a 50mm. I think that will do, a tele hood might give you some vignetting IMHO.
02-26-2013, 09:09 AM   #4
Just1MoreDave's Avatar
I know a 1"/25mm deep hood with 49mm threads and a 58mm opening works, because I've been using that all month on the F version, same optical design. The old ones that I have are labeled for 50mm or a standard lens. They work with my 58mm caps so I can cap the hood, still a compact package. It looks like you could go another half inch/12mm before any vignetting. The hood meant for the Takumar 135mm f3.5 is just a little too deep.
02-26-2013, 09:24 AM   #5
boriscleto's Avatar
After taking a look on a pure white backdrop, this hood is just slightly too long.
49mm Tele Metal Lens Hood for Canon Nikon Sony Olympus Z001 | eBay
There is very slight vignetting at minimum focus and more noticeable vignetting at infinity. The hood itself is just longer than the built in hood on the A135/2.8
02-26-2013, 09:47 AM   #6
johnyates's Avatar
This one will do you nicely:
49mm metal standard screw in mount lens hood for Canon Nikon Pentax Olympus Sony | eBay
02-27-2013, 09:00 PM   #7
Otis Memorial Pentaxian
What type of camera? If you are shooting with a Pentax dSLR (APS-C sized sensor), this one should work fine:
New Metal Standard 49mm Screw in Lens Hood | eBay
If you are shooting 35mm film, this will work:
New Metal Wide Angle 49mm Screw in Lens Hood | eBay
03-18-2017, 10:37 PM   #8
phs
I use the Pentax MH-RA 49mm lens hood on my A 28 2.0. It's the dedicated hood of the FA 43 1.9. On APS-C, there is some vignetting even without the hood. With the hood on, the vignetting looks about the same. So I guess the hood is perfect on APS-C. The hood is aluminum with felt inner padding. Really good build. Looks like they're made for each other. Wish I had a cap to go with it.
28mm, f2.8, hood, hood for smc, k-mount, lens, pentax lens, slr lens, smc
Wanted - Acquired: SMC Pentax 28mm F3.5, SMC Pentax-DA 35mm F2.4 AL, SMC Pentax-F 28mm F2.8 TMoneytron Sold Items 8 07-15-2012 02:54 PM
For Sale - Sold: Pentax SMC A 24-50 f4 & Tokina A 28mm f2.8 littledrawe Sold Items 9 06-06-2012 11:44 PM
For Sale - Sold: SMC A 24mm f2.8, 28mm f2.8, 50mm f1/7 leadfoot Sold Items 3 01-19-2012 06:15 PM
Hood for FA 28mm F2.8? legacyb4 Pentax SLR Lens Discussion 10 02-25-2009 11:43 PM
All times are GMT -7. The time now is 04:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
