02-26-2013, 09:06 AM   #1
Calibrating Lenses
I had read somewhere that Pentax DSLRs have built-in databases for automatically calibrating the attached lens. Is this true, or is it better to manually calibrate each of your lenses to each of your camera bodies?
I have a K-7 and a K-x, and I use a mix of Tamron, Pentax, and Sigma lenses.
cm
02-26-2013, 09:11 AM   #2
QuoteOriginally posted by charlestm Quote
cm
For Pentax DA and FA limited lenses, the camera supports in-camera distortion correction (very effective) and aberration correction (not very effective). These corrections can also be made when developing raw files, if you have the appropriate software.
02-26-2013, 09:47 AM   #3
jatrax's Avatar
As Adam says.
But if you meant auto-focus calibration then the answer is a little different. The k-x has only a single global adjustment. The k-5 can handle 20 different lenses and set an AF adjustment for each lenses individually. I THINK the k-7 is the same but I'm not 100% sure. And these must be done manually, there is no automatic way to do this.
02-26-2013, 10:22 AM   #4
Lowell Goudge's Avatar
As Adam says.
K7 has both individual and global adjustments, global adjustment is applied to unrecognized lenses, I forget how many individual adjustments it has
02-26-2013, 11:57 AM   #5
As Adam says.
Sorry for not being more clear. I was specifically referring to auto-focus calibration.
02-26-2013, 11:57 AM   #6
grhazelton's Avatar
Quite true, but the extra computations in the camera can really slow things down, as I discovered. I now use Lightroom's lens profiles for distortion correction.
02-26-2013, 12:54 PM   #7
Let me amplify that a little.
There is no official "AF fine adjustment" on the K-x,
so if you do want the single global adjustment,
you have to use a debug hack (at your own risk).
I've usually used the CDAF from live view
for critical accuracy on the K-x.
k-mount, lenses, pentax, pentax lens, slr lens
Calibrating Your Monitor macrogrl06 Troubleshooting and Beginner Help 9 01-24-2013 09:12 PM
Calibrating my Monitor krp Digital Processing, Software, and Printing 7 12-02-2012 04:24 PM
Calibrating AF on an *ist DS GibbyTheMole Troubleshooting and Beginner Help 10 10-06-2012 06:41 AM
Calibrating everything for lenses on the K-x? TMoneytron Troubleshooting and Beginner Help 13 08-06-2012 10:25 AM
Calibrating the split screen in my K100D - Question GibbyTheMole Pentax DSLR Discussion 3 03-15-2011 09:42 AM
All times are GMT -7. The time now is 09:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
