02-26-2013, 10:39 AM   #1
yorik's Avatar
Third party hood for da 21?
I am wondering if anyone has tried using the da 21 ltd with a third party hood, and if so what they can share about the experience?
Thanks,
Y
02-26-2013, 11:27 AM   #2
crewl1's Avatar
I really like the compact design of the OEM hood, so would not try a third party one on this lens.
I don't think you will find anyone using anything else.
What is it you don't like about the OEM one?
02-26-2013, 11:56 AM   #3
I use a 49-37mm stepdown adapter ring, followed by a 37mm "empty" ring (a filter with the glass removed).
02-26-2013, 12:30 PM   #4
siamthai's Avatar
I really disliked the OEM hood so I bought a third party from eBay. It's very much like the old Takumar hoods and it was good to use
49mm Metal Lens Hood Screw-in for Digital Camera Pentax Olympus standard lenses | eBay
I didn't like the OEM as it was not possible to use filters and one couldn't use a snap on lens cap.
02-26-2013, 12:50 PM   #5
yorik's Avatar
QuoteOriginally posted by crewl1 Quote
In point of fact, I don't yet own a da 21. I was asking about third party hoods, because I like using a circular polarizer with a hood screwed in the other side (I did this with the 43 recently and it worked nicely). Other than that, I think that I like the OEM hood, especially the way it protects the lens.
Thanks,
Y
02-26-2013, 12:55 PM   #6
crewl1's Avatar
Makes sense - I don't use filters yet much, probably need to check into that.
02-26-2013, 04:29 PM   #7
G_Money's Avatar
It's not the cheapest way to go but an Olympus 28mm hood will fit. You can leave it on and put a 58mm (I think) lens cap on it.
Second from the left.
eBay
02-26-2013, 08:50 PM   #8
yorik's Avatar
Thanks. I may also try the FA 43 hood...
02-27-2013, 09:52 AM   #9
QuoteOriginally posted by siamthai Quote
i am using a similar hood for da21 also...
02-28-2013, 09:26 PM   #10
tabl10s's Avatar
Since I don't polarize, the OEM is good. Set-n-forget.
da, hood, hood for da, k-mount, party, pentax lens, slr lens, third
Third Party Hood for DA21 pakinjapan Pentax SLR Lens Discussion 10 11-20-2012 09:11 AM
Third Party Lenses for 645D carlprad Pentax Medium Format 6 05-25-2011 11:53 AM
Third party hood for FA 31mm? alfdog Pentax SLR Lens Discussion 8 01-11-2011 05:29 PM
DA 70mm users ... third-party hood or not? JJJPhoto Pentax SLR Lens Discussion 6 05-29-2008 03:12 AM
All times are GMT -7. The time now is 03:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
