Originally posted by post_eos So that you can turn them once you have the adapter on and make the aperture scale end up in the correct place. The T mount thread doesn't always start at the same point on every lens. You loosen the screws, turn the lens to the correct position and then lock the screws back down.
Right! I probably knew that, but it has been awhile since I've used one of those and I'm not sure I've ever needed to adjust one. I have one t-mount adapter (like the one on ebay I linked to) which is just a solid piece and alignment has always been fine, although I only have a couple t-thread lenses...
