02-26-2013, 04:05 PM   #1
Lurch's Avatar
Flexar 400mm f6.3
Morning all,
I recently picked up an old Flexar 400mm 6.3. I'm assuming its just a generic lens of some description?
Anyway; the mount point is this:
It seems removable with the three little screws; but is this some kind of generic mount piece? Can I get a K-mount version to replace it?
Cheers,
Lurch
02-26-2013, 04:13 PM   #2
boriscleto's Avatar
T-mount - Wikipedia, the free encyclopedia
You will need a T-ring adapter to attach it to the camera. For example...
General Brand T-Mount SLR Camera Adapter for Pentax K ATPK B&H
You should be able to get one cheaper locally.
02-26-2013, 04:15 PM   #3
Lurch's Avatar
*Ding* - thanks mate.
I thought that was the case, but I got confused between a t-mount and an adaptall?
02-26-2013, 04:19 PM   #4
boriscleto's Avatar
QuoteOriginally posted by Lurch Quote
Adaptall is a later mount that allowed for automated aperture.
Matt's Classic Cameras: Tamron Adaptall-2 System
The other systems were Soligor's T4 mount which evolved into the Vivitar TX mount. Sigma had the YS mount.
02-26-2013, 04:22 PM   #5
Lurch's Avatar
Ahh - gotchya.
BTW; is there any real benefit to replacing the T-Mount as opposed to just using a M42/K adapter on teh existing T-Mount?
02-26-2013, 04:29 PM   #6
Ahh - gotchya.
No, just get an adapter. That's what you're supposed to do -- there is no such thing as "t-mount camera".
They're cheap. This one is good:
T2 T Mount T Ring Adapter for Pentax K PK K 7 K x K20D | eBay
The thing that is removable probably *is* an adapter -- m42 I suspect. Underneath it are the t-mount screws (which are also 42mm, but different pitch).
02-26-2013, 04:34 PM   #7
Lurch's Avatar
Ahh - ok; let me re-phrase that..
I figure I can either:
Get a whole new T-Mount > PK Adapter or
Just get a M42>PK adapter to screw onto the existing T-Mount > M42 adapter.
02-26-2013, 05:00 PM   #8
boriscleto's Avatar
There are 2 parts to the T-mount. The first is the T-mount adapter that is already on the lens. That is a 42mm x .75 mm thread pitch. (M42 is 42mm x 1mm). The second part is the T-ring adapter. That is the part that mounts the lens to the camera. What you need is the T->PK ring.
02-26-2013, 05:05 PM   #9
One adapter or another, yes. Don't spend too much -- that lens probably isn't worth it. There are a million of those generic t-mount 400/6.3s out there and most of them are relatively crappy. Expect heavy lateral CA on the edges -- this is a lens that actually becomes sharper in post-processing if you have Lightroom 4 or similar because it will rescale the misaligned colors. You can get a decent image of it (at least in the center) if you stop down to f11 and use a tripod.
02-26-2013, 05:11 PM   #10
As Boriscleto says, the thread pitch is different, You will be able to screw the M42 adapter on the T2 mount about 1 turn before it stops, if you try forcing them together, you'll ruin one or both parts, rendering your lens useless. Safest to get a T-K ring.
02-26-2013, 05:29 PM   #11
Lurch's Avatar
Hmm...
This lense only seems to have one 'bit'
And the screw size is definitely M42
02-26-2013, 05:36 PM   #12
I think you've left part of the adapter on -- t-mount adapters are often built like that with an inner ring that comes out. You should be able to unscrew the remaining ring...
02-26-2013, 05:46 PM   #13
Lurch's Avatar
Ah-HAH!!
Thanks guys!
02-26-2013, 05:54 PM   #14
Yeah, so you could have just unscrewed it I guess (sometimes they are locked down though). So that ring goes back in the adapter -- not sure why they make them like that...
02-26-2013, 05:56 PM   #15
Lurch's Avatar
So its the bit on the far right I want to replace with a K version?
I cant help but think that with this lens meaning to sit on a tripod, just putting a simply M42>K adapter would have the strength.
400mm, flexar, k-mount, mount, pentax lens, slr lens
For Sale - Sold: Optomax (Tamron made) 400mm f6.3 cheekygeek Sold Items 2 05-22-2012 05:55 PM
For Sale - Sold: Bushnell 400mm f6.3 M42 lens & 2X TC gsrokmix Sold Items 1 01-11-2012 04:10 PM
For Sale - Sold: Komura 400mm f6.3 (screw-mount, preset) Price dropped! Rorschach Sold Items 1 11-30-2011 10:28 AM
Tokina 400mm f6.3 lens (M42 mount) geekette Pentax SLR Lens Discussion 17 06-01-2011 01:12 PM
All times are GMT -7. The time now is 02:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
