02-27-2013, 11:03 AM   #1
PBandJ's Avatar
I want to understand the different series of lenses from Pentax
\Body: K01
ok, I know DA/DA-L = autofocus & autometering
then there's:
F =
FA =
A =
M42 =
can someone give me a qwikndirty summary? I'm getting confused when looking at FA, F, A, DA lenses.
Also do some A lenses not do autometering- if they don't have an A setting?
I know that some have quickshift, metal mounts, etc, but in this thread, I would like to understand which lens offers what in terms of focus and autoaperture/need to use green button.
02-27-2013, 11:07 AM   #2
Docrwm's Avatar
https://www.pentaxforums.com/forums/pentax-lens-articles/114925-pentax-lenses...ns-reflex.html
02-27-2013, 11:07 AM - 1 Like   #3
F = Autofocus, auto-aperture
FA = Autofocus, auto-aperture
A = manual focus, auto-aperture (all have an "A" setting)
M42 = manual focus, manual aperture, no green button, viewfinder becomes dimmer as you stop down
K = manual focus, manual aperture, use green button
MK = manual focus, manual aperture, use green button
02-27-2013, 11:19 AM   #4
PBandJ's Avatar
QuoteOriginally posted by alphanerd Quote
thank you SOO much!
so as a lens buyer, DA, FA and F work the same. I didn't realize that.
02-27-2013, 11:24 AM   #5
PBandJ's Avatar
thanks Doc, hadn't seen that table
02-27-2013, 11:25 AM   #6
Docrwm's Avatar
QuoteOriginally posted by PBandJ Quote
No problem. Hope it helps.
02-27-2013, 11:28 AM   #7
boriscleto's Avatar
Don't forget this either...
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
The FA 28 soft and the FA 85 soft don't have an A setting. They have to use stop down metering just like the K and M series.
02-27-2013, 12:00 PM   #8
Docrwm's Avatar
M42 also require an adapter to fit onto modern dSLRs (M42 to K adapter).
02-27-2013, 12:00 PM   #9
normhead's Avatar
thank you SOO much!
Except the one F lens we have will scare away wildlife when it focuses and will crank your wrist when it stops if the focus travel was a long distance.
02-27-2013, 12:04 PM   #10
monochrome's Avatar
Shoot that lens on an SF1 and scare wildlife in the next county
02-27-2013, 12:08 PM   #11
Docrwm's Avatar
If you have a K-x the shutter noise will get you arrested for hunting without a license in many states.
02-27-2013, 12:10 PM   #12
don't forget, DA lenses are APS-C sized image circle, the others "full frame"
02-27-2013, 12:17 PM   #13
Na Horuk's Avatar
And DA L are the same as their DA counterparts, but with cheaper overall build. They come without a hood, they don't have quickshift, they have a plastic mount, don't allow CiF.. and they may have a different filter size.
most DA lenses are APS-C sized, which means that on a full frame or film camera they might have heavy vignetting on the edges. But some were tested on film cameras and some are just fine, there is a thread about this, it includes a list on which DA lenses project a full frame circle and which an crop circle. DFA are modern lenses that can definitely be used on full frame.
Other things you should learn about is WR (weather resistant. If you have a WR camera, it will only be really WR if the lens is also WR) and then the difference between regular lenses, star (*) lenses, and limited lenses. These are basically higher quality than regular lenses, but also more expensive.
02-27-2013, 12:20 PM   #14
PBandJ's Avatar
thanks, the most confusing thing was what I would be required to do using each.
Which F lens are you guys talking about? Not the 70-210 hopefully!
Also, some Vivitar Series 1(2.8-4, Komine) reviews say they have the A setting. Does someone have a picture of what that looks like? Is it just the aperture ring?
02-27-2013, 12:23 PM   #15
jatrax's Avatar
Absolutely! Whir, whir, bang! Focus locked!
fa, k-mount, lenses, pentax lens, slr lens
I mustn't understand the Quick-Dial - if I do, Pentax are deliberately being daft tclausen Pentax Q 11 07-26-2012 02:15 PM
"We cannot force someone to “understand” something they do not want to understand" jeffkrol General Talk 1 06-25-2012 07:16 AM
Anybody want to share their Photos taken from your K Series Cameras music_lover Pentax DSLR Discussion 6 06-10-2010 05:02 PM
I want some light, sharp, fast prime lenses...hopefully I came to the right place innocent smith Troubleshooting and Beginner Help 15 04-21-2010 02:51 AM
I want to get rid of the image in the signature, how? pcarfan Site Suggestions and Help 4 03-25-2009 01:35 PM
All times are GMT -7. The time now is 10:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
