03-04-2013, 05:26 AM   #76
Digitalis's Avatar
QuoteOriginally posted by goubejp Quote
FA 400 f5.6
That lens has a purple fringing problem, similar to the M42 400mm f/5.6
03-04-2013, 03:56 PM   #77
twitch's Avatar
QuoteOriginally posted by Alizarine Quote
Can't they just update the FA*24 to D FA*24 and make it WR too?
I hope not, it is not a very good lens and needs a re-design, it is no where near FA limited quality. It's not sharp enough where it should be, and the bokeh is just plain bad. This is the opposite of the FA limiteds. Mind you I don't think the DA21 is very good either, seems Pentax has trouble designing good lenses around this focal length.
03-04-2013, 09:41 PM   #78
Digitalis's Avatar
QuoteOriginally posted by twitch Quote
I agree, the DA15mm f/4 has problems competing against my sigma 8-16mm f/4.5-5.6 at 15mm. Lenses wider than 28mm have always been problematic for lens makers in general - pentax isn't alone here. However on the 645D the 25mm f/4 actually is quite an impressive piece of glass that competes favourably against competing medium format ultra wide lenses from Leica, Schneider and Mamiya. On the 645D the lens is a 19.5mm equivalent, on full frame 645 it is a 15mm lens in 35mm terms, IMHO pentax can make a wide angle lens worth a damn - What consumers are willing to pay for it is holding them back.
03-04-2013, 10:16 PM   #79
Did you get a bad copy of FA*24? Can you post some shots taken by your copy?
On mine, center is very sharp wide open with corners peaking at around f5.6-f8. Sure, there are CA and PF here and there, but they are easily removed (if I remember to) in LR. Too bad there is no profile for this lens in Camera Raw.
03-04-2013, 10:29 PM   #80
twitch's Avatar
QuoteOriginally posted by chesebert Quote
I really didn't like the bokeh at all, had this disturbing double image kind of quality to it, nothing like a FA31.
03-04-2013, 10:41 PM   #81
Digitalis's Avatar
I have a copy of the FA*24mm f/2 somewhere, it was a decent lens on film - but something seems to have gotten lost in the translation to digital.
03-04-2013, 10:58 PM   #82
I hope you still have it with you. Would like to see an old shot from film (so as not to make another one now) and a new one in digital if you have time or if it isn't much of a bother. There's a seller locally who's offering it up for quite a good price but I'm doubtful since I already have the (legacy but newer, and anyway good enough) Sigma 24 2.8. 24mm is one of the most sought-of WAs in APS-C nowadays.
Hmm, how bad is it against the FA31? Or if you've tried out the DA (L) 35 f2.4 (on IQ alone, never mind the FL)
03-04-2013, 11:06 PM   #83
Nothing is like FA31.
I also don't see why bokeh is so bad compared to other limiteds. This one was shot at f4.0 ISO1600, IIRC
03-04-2013, 11:20 PM   #84
double post
03-04-2013, 11:44 PM   #85
Digitalis's Avatar
You can see the dark centred bokeh circles on specular highlights - which is why the FA*24mm f/2 produces such harsh bokeh. As I recall the Japanese call it "neisen bokeh" - meaning double lined blur. The Ideal bokeh disc has a evenly lit centre which gradually darkens towards the edge.The FA*24mm f/2 it works the other way around slightly darker centre - with bright green/magenta fringed edges.
Quite right, the only lenses that are somewhat better than the FA31 have red dots on them and cost three times more.
03-05-2013, 12:02 AM   #86
I see. Great, now I can longer be satisifed by my copy of FA*24
Here is FA31 at f4.0 with similar half body shot
03-05-2013, 12:51 AM   #87
I think you may make a confusion between the M42, which was available later as Pentax A 400 F5.6 (which I have owned) with the same optical formula, and no ED glasses, and the FA version, with a new optical design including ED elements.
03-05-2013, 01:41 AM   #88
twitch's Avatar
Here's an example of what I didn't like, a crop (about 60% of the frame) of a FA*24 shot
03-05-2013, 02:59 AM   #89
sTi
Smooth bokeh was obviously no consideration in the design of this lens...
Sadly, the same is true for its digital successor (field-of-view wise), the DA 15, as great as it is otherwise...
03-05-2013, 03:46 AM   #90
Digitalis's Avatar
QuoteOriginally posted by sTi Quote
I wouldn't write the bokeh of the DA15 ED ASPH Limited off that easily, granted you do have to be really close to your subject and stop i the lens down a bit to get some really smooth effects, but it certainly has potential:
Pentax K7- Pentax DA15mm f/4 ED ASPH Limited 1/640th f/5.6 ISO 200
k-mount, pentax lens, slr lens
Computers and Cameras - or Bring Back Remote Assistant Northern Soul Pentax DSLR Discussion 2 04-10-2012 09:23 PM
Bring Back Boring Banks (NYT op-ed) jolepp General Talk 3 01-05-2012 09:30 AM
Do you use the in camera color settings? why or why not? SlickYamaha Troubleshooting and Beginner Help 13 08-13-2011 09:36 PM
85mm glass...why so expensive? (Not work-safe) PollitowuzHere Pentax SLR Lens Discussion 83 09-26-2009 09:22 AM
Say no to pixel peeping - Bring back the latent image! ChrisPlatt General Talk 6 09-06-2009 06:22 AM
All times are GMT -7. The time now is 06:43 AM. | See also: NikonForums.com, part of our network of photo forums!
