Originally posted by lesmore49
Is it capable of taking very sharp photo's ?
Is it fairly good at taking action shots...when hand held or on a mono pod ?
Does the bayonet mount connect well with the Pentax body ?
Is it reliable, durable and robustly made ?
In the future, if Pentax brings out a full frame DSLR I may just buy one. I understand that the Sigma 150-500 will work with both a full frame and a cropped sensor such as an ASP-C. Is this the case ?
Hi - I have posted one of the reviews of this lens elsewhere on this Forum.
In answer to your questions:
- yes it is capable of taking sharp photos - but a lot depends on experience with the lens, and taking your time to practice, especially if you have never used a long 500 lens.
- fairly good is subjective - it can be heavy to hand hold for long periods - but I have seen very good action shots taken with this lens - Pentax & other brand cameras. Using a mono pod would be very useful.
- yes mounts perfectly - I have a number of Sigma lenses and none have had mounting issues - i've used them on K100/ K10/K7 & K5.
- Yes to all of the points - however I have heard it said older Sigma had quality control issues - I've seen some pretty bashed up Sigma's with loss of paint etc, but I have had no problems.
- The 150-500 is a DG so it therefor is Full Framed - Sigma DC lenses are APS-C similar to the Pentax DA.
The 150-500 also has 2 types of in lens Stabilization which does help @ the long end - but switch off the Pentax in body if you use the in lens Stabilization.
The only downside is that the lens is slowish @ the long end - but I don't have $12k + to spend on a faster lens.
Hope this helps.
Kevin
