Interesting series. Too bad the tripod was moved in between lens changes.
Were you using the M42 Auto Sears 55/1.4*? If so, I have the same lens with Ricoh label. Based on my experience with that lens, I would have to place the Sears as the first in the grouping (it sucks wide open and lags my Pentax lenses overall). I also own the Pentax-K. I place it one of the two middle entries. That leaves the Auto-Tak at the end...placed there due to slightly lower contrast. I own that lens as well, though with Super-Tak labeling (yes, it has the reverse direction focus). This is tough since all three of the Pentax lenses share a common design and should differ only in their coatings.
My guess is:
- Sears 55/1.4
- SMC Tak 55/1.8
- Pentax-K 55/1.8
- Auto-Tak 55/1.8
It was tempting to cast the Sears as the "warm" entry. My copy has a distinct yellow cast to the glass, but no way does it perform as well as any of the warmer samples above
*Figured it out by looking through your photostream. Yep, same lens. That is a nice black Sears TLS too.
