Originally posted by imtheguy I quit 2x teleconverters years ago since the loss of IQ was always worse than just cropping. However the Sigma 1.4x on their 500mm prime exceeded my expectations. Now I wonder if the 2x TC has a chance to do the same. Has anybody here in PF tried that combo and wish to recommend it? any pictures posted?
Thanks in advance.
I conducted a quick test today. I shot the test chart in the first photo below from about 32', which was the distance at which the chart filled the frame of my K-5 with Sigma 500mm F4.5 and Sigma 2x TC attached. I was outdoors in good late afternoon light. I shot several frames at f5.6, ISO between 100-200 as reported by the K-5 (actually it was 2 stops slower than f5.6 because the Sigma TC simply passes through the info from the lens to which it is attached -- the K-5 doesn't know about the TC). The camera was locked down on a good quality tripod and gimbal. I used autofocus. I fired the shutter remotely 6 sec after mirror lock-up. Then I removed the TC and did the same thing again with the same f -stop and ISO, letting shutter speed go up to keep roughly the same exposure values. Then I cropped both sets of photos to display the same field of view on the most telling part of the test chart. Two samples are reproduced below.
Every sample generated the same conclusion: The images taken with the Sigma 2x TC (e.g., the first example) are sharper than from the images w/o the TC (the second example) when the latter images are cropped to the same field of view as those obtained with the TC. I think the difference is clear from the attached jpegs. It is crystal clear with the raw files. This surprised me and will affect my behavior going forward -- like I may actually use the 2x TC.
Russ
