02-28-2008, 06:06 PM   #1
Extreme wide angle choices
Is it worth the wait for the Tamron 10-24? or should I just go for the Pentax 12-24?
Is there any news on release dates or prices for the tamron?
What other options do I have
02-28-2008, 06:08 PM   #2
Lowell Goudge's Avatar
the sigma 10-20 is also a fine lens. Sigma also make a full frame 12-24 if you are into film, which will give you a really extreme wide angle compared to 10mm on an ASP-C sensor
02-28-2008, 06:13 PM   #3
I just bought the Sigma 10-20mm f/4-5.6 and I am very happy with it. There are good and bad with each lens. Check out the tests on each lens.
I chose the 10-20mm because the sharpness is nearly the same as the Pentax 12-24 at the same mm, without the horrible CA. Photozone.de rates the Pentax 12-24 higher than the Sigma 10-20, but I wanted the extra 2 mm, which in this range that is about 20% more picture.
I highly recommend the Sigma for it's sharpness and the extra 2mm wide.
02-28-2008, 06:27 PM   #4
QuoteOriginally posted by TomInJax Quote
Tom
Good point that I forgot to mention. Last year, since I bought my 10-20, 20% of all my shots were below 20mm and 12% were AT 10mm.
If you now gave me the 12-24 I would miss the 10mm width
02-28-2008, 09:39 PM   #5
SpecialK's Avatar
There is also the obvious choice of the 10-17.
02-28-2008, 09:46 PM   #6
Gooshin's Avatar
the 10-17 is a fisheye and has extreme barrel distortion
the 10-20/12-24 are rectalinear and have linear distortions, the effects are drasticaly different and IMO should not even be compared.
02-28-2008, 10:05 PM   #7
SpecialK's Avatar
Of course, that's the nature of a fisheye. Not for everyone, though.
Shouldn't be afraid to compare. There was no limitation in the original post, sorry, except extreme" was mentioned. The ultrawides have distortion too - lines lean in - which can be distracting.
02-28-2008, 10:33 PM   #8
Gooshin's Avatar
the way you said "the obvious choice" makes it seem like the sigma/pentax have no business even existing.
02-28-2008, 10:42 PM   #9
SpecialK's Avatar
I have the Pentax 12-24, and 2 Sigmas, as indicated. But don't worry about it :-)
Oh, and the Zenitar 16mm MF lens seems to be popular with some people. I think it's under $200.
02-28-2008, 10:43 PM   #10
If you truly want extreme wait until Sigma makes their 4.5mm F2.8 EX DC Circular Fisheye available in a Pentax mount
I don't believe that they've announced it yet, however I'm sure they have it on their mind.
02-28-2008, 10:59 PM   #11
QuoteOriginally posted by Stoosh Quote
A month ago, I also had that same problem because I really wanted and needed an ultra-wide angle lens. I was choosing between these lenses:
Pentax-DA 14mm F2.8 - It's a big large though, but I hear the IQ is very good. A bit pricey, but manageable.
Pentax-DA 12-24mm F4 - Quite expensive, very bulky front section, but very good IQ. It's not a prime though and I lean towards primes over zooms most of the time.
Sigma 12-24 mm F4.5 - Around half the price of the Pentax version, but as far as I hear, it also shows in the quality of the images. It's also an f-stop slower.
Pentax-DA 21mm F3.2 Limited - Not really UWA for me, so it's not as wide as I want to go. But in terms of size and IQ, it's great. Add that to the fact that it's a Pentax prime and it's a limited (I LOVE my 40/2.8). A bit pricey, but manageable. Having said that, I'm still pretty sure it's not as wide as I want to go.
Pentax also announced the 15mm ltd on their roadmap so that made my mouth water and i wondered if i should wait for it.
I actually posted all this on this thread over at dpreview.
It was all really funny because right now, I already made my choice and my purchase, and that's the Sigma 10-20mm f4-f5.6 lens.
Some people brought that lens to my attention over at that dpreview thread and I really found that a lot of people love the 10-20. I researched on it and canvassed prices. Eventually, it appeared as the most promising of all my choices so I went ahead and bought it. I don't regret the choice one bit and I use the lens almost always at 10mm.
The news of the Tamron 10-24 did make me hesitate a bit; but I realized that that lens might be around a year from being released, and if I really wanted it once it came out, I could just sell my Sigma 10-20 and buy the Tamron 10-24... but I'll just cross the bridge when I get there,
Basically, my opinion is that you should seriously consider the Sigma 10-20 and the fact that most users of this lens use it at 10mm almost always.
02-28-2008, 11:04 PM   #12
QuoteOriginally posted by little laker Quote
I'm not sure but I believe you can't make a lens with a FL shorter than 8mm, unless it has a huuuuuuge front element that extends beyond the body's height and width!
02-28-2008, 11:05 PM   #13
I know that it isn't on a Pentax mount, however I think that some people might like the effect of the Sigma 4.5mm lens.
found in the Sigma section at dpreview here
I haven't confirmed it, but I believe that's how much the lens really vignette's
02-28-2008, 11:13 PM   #14
hinman's Avatar
question on Sigma 10-20
Can some owner of Sigma 10-20 confirm if the Sigma works with both digital as well as film cameras? And how about the focusing ring on the Sigma, is it wide enough that it also works well for manual focus in film cameras?
Thanks,
Hin
02-28-2008, 11:15 PM   #15
Hm, you could call this vignetting, but circular fisheye has angle of view of 180°, and it makes circular image (it sees everything in front of it), so, the image is circular. Black corners are simply part of sensor that is not being used.
k-mount, pentax lens, slr lens, tamron
Extreme wide angle portraits (not fisheye) levelred Pentax SLR Lens Discussion 22 04-09-2010 11:30 PM
Ultra-Wide Choices? potatolicious Pentax SLR Lens Discussion 16 10-29-2009 05:36 PM
Pentax extreme wide angle lenses-where are they? lesmore49 Pentax SLR Lens Discussion 15 10-14-2009 03:27 AM
Super Wide Choices? Okami Pentax SLR Lens Discussion 17 05-28-2008 06:05 PM
Wide angle Choices daacon Pentax SLR Lens Discussion 20 05-22-2007 10:36 PM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
