03-07-2013, 04:43 PM   #1
Pentax-m 85mm f2 VS Jupiter 9
Which lens is better for a wedding video? on a crop sensor?
thanks!
03-07-2013, 05:03 PM   #2
Assuming you can find a good copy of both and not one that has problems associated with age, the Pentax will probably give you better sharpness wide open at f2 and the the Jupiter will give you smoother, more attractive bokeh or background blur. I love my Jupiter 9 but I usually use it stopped down to between f/2.8 and f/8 (frequently using it at f/4).
If you plan to adjust the aperture while shooting video then I recommend the Jupiter 9 because changing the aperture is smoother without the hard clicks of the aperture ring on the Pentax 85mm.
03-07-2013, 05:32 PM   #3
QuoteOriginally posted by JJJPhoto Quote
Shouldnt be a problem, i have a couple variable ND filters..
I have a helios 44-2, and the focus ring is near the back, is the Jupiter 9 like that too? I find it a bit inconvenient...
03-07-2013, 06:05 PM   #4
QuoteOriginally posted by iNicole Quote
Yes, many of the old Russian lenses use the aperture rings near the front and the larger focus rings in the rear
03-07-2013, 11:35 PM   #5
Aperture and preset rings are at the front with the focus immediately behind. The actual size and spacing depends on what flavor J-9 you have. For black models in native M42 mount, the focus ring is generous while the preset ring can be a little hard to manage (narrow clearance) if focus is near infinity.
Here is a picture of my copy mounted on a 35mm SLR to give you a good idea of layout and size.
(...there is a good review on this site and Google should give you a decent pictures of the variations...)
03-08-2013, 12:18 AM   #6
kent's Avatar
Here you can see how the stepless aperture of jupiter works on video
03-08-2013, 11:29 PM - 1 Like   #7
QuoteOriginally posted by kent Quote
Here you can see how the stepless aperture of jupiter works on video Jupiter-9 aperture test - YouTube
For clarification...the aperture ring on a J-9 has stepped click stops. It is the stop-down (pre-set) ring that is stepless. The trick is to set the aperture at f/16 and use the pre-set ring to smoothly close the blades.
03-09-2013, 12:40 AM   #8
kent's Avatar
You are right
k-mount, pentax lens, pentax-m 85mm f2, slr lens
For Sale - Sold: JUPITER 9 - 85mm f2 M42 camacho Sold Items 2 07-09-2012 01:00 AM
Need help... Jupiter 9 85mm f2 HoBykoYan Pentax SLR Lens Discussion 53 02-29-2012 09:04 AM
Which 85mm: Takumar 1.9 vs Rokinon 1.4 vs Jupiter-9 yusuf Pentax SLR Lens Discussion 7 04-10-2010 03:21 PM
Jupiter-9 vs. Samyang/Vivitar/Rokinon/etc 85mm deadwolfbones Pentax SLR Lens Discussion 3 10-23-2009 05:47 PM
For Sale - Sold: Jupiter-9 85mm f2.0 Gooshin Sold Items 22 03-13-2009 12:42 PM
All times are GMT -7. The time now is 04:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
