Originally posted by Lloydy That looks exactly the same as the infamous blue spot on the Tamron 90 2.5 macro, which is a superb lens in every respect except this blue spot. Which as Steve says, is most likely a reflection of the sensor on the flat rear element.
With my Tamron I can see it in the viewfinder as it occurs and changing position so the flare through the lens doesn't reflect gets rid of the blue spot. I didn't finda hood a great deal of help - some help but not enough to get rid of it. I experimented with different hoods and apertures with the camera on a tripod.
Latest info on SP 90 "spot", from somebody who talked with Tamron employee at a trade show, is the rear compensator group of elements is uncoated (thus the reflections), that the lens is designed for low contrast lighting at high magnifications. I suspect other lenses that exhibit these spots have uncoated elements.
Originally posted by stevebrot The thorium is in the glass not the coatings and was added to change the refractive index. There is some discussion as to what actually turns yellow. There are users here that have stated that it is the coatings that turn in reaction to the radiation. I have seen convincing reports on the Web that indicates that glass itself is discolored. For years, it was my opinion that the yellowing was the balsam cement used in grouped elements (have my doubts now). Regardless of the cause, the lens can be bleached by exposure to sunlight or another source of UV light.
Thorium doped glass is well known, however, Gerjan van Osten says, in "The Ultimate Asahi Pentax Screw Mount Guide" (1999), there is thorium in one of the coatings. Since Mr. van Osten had access to Asahi Pentax personnel and documentation, I tend to believe him.
