03-11-2013, 01:55 AM   #1
Lurch's Avatar
Current lenses on a FF
I've been carefully reading all the discussions and so forth on the (hopefully) up coming Pentax full frame.
However I'm still confused as what this will mean for my current collection of lenses.
Now, I'll assume for a sec that Pentax wont do anything stupid like chance the K-Mount, so physically (I hope) lenses will still fit. But what will it mean?
Will my lenses just change they're designated focal length? (eg a 50mm will actually work like a 35mm) Will there be horrid vignetting? Or is it like dividing by zero and the world will implode?
Cheers,
Lurch
03-11-2013, 02:32 AM   #2
Focal length does not change. Field of view does. So to fit the same scene into the frame you will need a lens 1.5x the focal length. (For those of us who grew up with 35mm film, lenses go back to their 'proper' field of view.)
DA lenses are only designed to cover the APS-C sensor so yes there will be very severe vignetting issues with some of them, and failing that edge softness on some of the rest. I think there's a few threads here on testing DA lenses for FF performance (using film bodies). Some of them actually seem to be OK - by liuck or by virtue of recycled FF optic designs perhaps?
FA, A, M, K, M42 lenses should all be fine as a FF sensor (by definition) covers the same area as the 35mm film frame.
03-11-2013, 02:38 AM   #3
Lurch's Avatar
Ok; thanks for that. Any thought on Sigma stuff? The rest I dont really care about except my much loved 20-40mm
03-11-2013, 02:39 AM   #4
QuoteOriginally posted by Lurch Quote
Cheers,
Lurch
Sensor size doesn't change focal length, just field of view. On FF, your FF compatible lenses will have the field of view native to their focal length (while on crop it is different). For example, on FF 50mm FOV is 40 degrees, on crop - 20 degrees.
Check this thread about vignetting. https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/31629-da-lens-...ts-thread.html
03-11-2013, 02:55 AM   #5
Lurch's Avatar
Ahh, ok. So its the increased FOV therefore that causes vignetting/soft edges?
03-11-2013, 03:02 AM   #6
I believe that vignetting appears when sensor size is too big for lens "hole" to fully cover.
03-11-2013, 03:07 AM   #7
Lurch's Avatar
Ok; it sounds for a lot of lenses, it will be a case of 'suck it and see'
03-11-2013, 05:38 AM   #8
Picture this- or even try it. Hold a piece of paper a few centimetres behind a camera lens and it will project an image of the scene on the paper. Hold it at just the right distance and it will be in focus. (If you want to actually try this you will need a bright scene and an otherwise darkly lit piece of paper, e.g. in a dark room with the lens pointing through a small opening through a blind, out a window.
The image will have a brightest point and will fall off from there. A FF lens should make an image that covers a 35x24mm frame with minimal fall-off. A lens designed for digital - including Sigma DC series - may potentially only cover a smaller APS-C sensor area. Or even if it extends further, it may have poor IQ out there.
03-11-2013, 06:30 AM   #9
Moderator PEG Judges
Kerrowdown's Avatar
I'm just lucky all my current lenses all FF.
01-06-2014, 05:56 AM   #10
TS, you may like to check out this thread I started
https://www.pentaxforums.com/forums/169-pentax-full-frame/246917-does-my-m42-...ploration.html
Hold on to those FF lenses
01-06-2014, 10:17 PM - 1 Like   #11
6BQ5's Avatar
You can easily test the vignetting yourself. Get a cheap (even broken) film Pentax SLR and mount whatever K-mount lens you want. The DA 18-55mm kit lens easily shows vignetting at 18mm through the viewfinder.
You'll probably pay more for S&H than the actual camera itself. Let me know if you want one for grins.
k-mount, lenses, pentax, pentax lens, slr lens
Big Savings on Nikon FF Lenses Adam Non-Pentax Cameras: Canon, Nikon, etc. 3 02-26-2013 09:32 AM
A Pentax FF idea, a unique take on the FF market... theperception2008 Pentax DSLR Discussion 20 10-03-2012 01:07 PM
Current DA lenses fit for FF? or not? soalle Pentax SLR Lens Discussion 15 09-23-2012 02:36 PM
Digital FF KAF lenses on a Pentax MX? zantaphia Pentax Film SLR Discussion 6 01-25-2012 01:16 PM
Hyperfocal adjustment on current vs manual lenses kbrede Pentax SLR Lens Discussion 41 03-22-2011 10:52 AM
All times are GMT -7. The time now is 06:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
