03-12-2013, 07:42 PM   #1
DA 21 and Vignetting with a Lee/Cokin filter system?
I am almost entirely a landscape photographer but have been noticing that I often try to do too much with my shots and often go wider than necessary (I recently purchased a pano head for my tripid and use it frequently). Anyway, I will be buying the DA 21 to try to force myself to scale back a bit and work on creating a central focus in my images instead of simply capturing as much as possible.
So, my question is: has anyone used the DA 21 with a Lee/Cokin filter system? I own the Lee 77mm ring adapter and would ideally like to just buy a 49 - 77mm step up ring to use with it but I am worried that it may cause some vignetting. Of course I could just buy the 49mm adapter, but the price is ridiculous for that small piece of metal.
According to Photozone.de, this lens has minimal vignetting when stopped down which is great. I wasn't sure if this stands true with a rectangular filter system attached, especially when used in conjunction with a step up ring. Anyone have experience with a set up like this?
03-12-2013, 07:56 PM   #2
mattt's Avatar
Just took a quick look back through my archives.. I know I've had a 49->52 stepping ring and 2x HOYA ND8 52mm with no vignetting. I don't have Lee/Cokin kit..
03-12-2013, 08:24 PM   #3
jatrax's Avatar
I've used mine with the Cokin A system using a 49mm ring and never noticed any vignetting. Never used Lee but aren't they bigger, 100mm? Cokin A is 70mm. I cannot see how it would cause a problem.
03-13-2013, 07:53 AM   #4
Ya, Lee is definitely larger. I suppose I will give it a try. Worst case I can just purchase a new Lee adapter ring.
03-13-2013, 08:00 AM   #5
Miguel's Avatar
No vignetting in my experience. I find those holder adapters, step-up rings etc. to be a waste of money and a hassle to setup and handle. I just hold the filter against the lens.. With a squat lens like the 21mm it is very easy.
M
03-13-2013, 12:09 PM   #6
jatrax's Avatar
QuoteOriginally posted by Miguel Quote
M
Yes that works, but for a 20 second exposure standing in icy water shooting waterfalls, I'll use the holder
03-14-2013, 10:59 PM   #7
Digitalis's Avatar
Correct, standard Lee ND grad filters are 100x150mm. Apart from the annoying tabs for the built in lens hood on my DA15mm f/4 ASPH Limited I have used the Lee filter system without issue. I simply use de-glassed slim frame UV filter to extend the filter thread to attack the lee filter holder.
Pentax K7 - DA15mm f/4 ASPH ED Limited with Lee "big stopper" 10 stop ND filter - 45s f/11 ISO 100
03-15-2013, 05:03 AM   #8
bdery's Avatar
QuoteOriginally posted by turff Quote
For the record, that is an excellent choice for what you have in mind.
77mm, adapter, da, filter, k-mount, lee/cokin, pentax lens, slr lens, step, system
For Sale - Sold: Magnifying eyepiece, Cokin creative filter system zhuxyg Sold Items 2 09-04-2011 09:32 AM
Cokin filter System kyteflyer Pentax Camera and Field Accessories 49 02-07-2011 06:03 AM
Pentax 6x7 45mm: Vignetting using Cokin Z-Pro filter holder? leoyblam Pentax Medium Format 2 08-19-2010 08:04 PM
Cokin Z-pro filter system with 6x7 lenses? Denverdad Pentax Medium Format 6 06-21-2009 10:39 PM
All times are GMT -7. The time now is 10:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
