03-13-2013, 06:36 PM   #16
RobA_Oz's Avatar
QuoteOriginally posted by wlachan Quote
I thought HSM was from Sigma? Anyway, SDM is cursed and people have been warned since the beginning. The argument of QC issue from other manufacturers is just silly IMHO because C/N 2.8 zooms can AF far faster than anything SDM. They fail because of either defective motors or wear and tear, not substandard designs like SDM. If high performance 2.8 zooms are that important, why not just pick what are available on the market now instead of dreaming Pentax might address the damn SDM on day which may not come?
That may be so, but I would have thought they would all have been using the same drive motors from the same group of manufacturers. I think it's been fairly well established now that the fault lies in the motor sticking, and not in the mechanism failing (reports of motors "burning out" are vague terms used to justify a replacement - piezo motors aren't like ac or dc motors, as there are no windings, brushes or commutators to burn out, and mine was just plain stuck, as were those of others who undertook the remedial process themselves). That doesn't rule out faulty design (probably selecting the wrong drive motor for the duty). So, the reality is that Pentax's SDM failures are much the same as those of the others, ie faulty motors, but failing earlier, where they fail at all.
03-14-2013, 02:10 AM   #17
Anvh's Avatar
What would you call this?
Not a design fault but a feature... sounds like Apple
Similarly the Canon 70-200 fails for a couple of different reasons, but jammed zoom rings are common and caused by a tooth breaking on the nylon ‘reversing’ gear under the zoom ring.
Here a bit about the Canon 24-70 f/2.8 wear and tear
LensRentals.com - The Limits of Variation
There is sadly always something
03-14-2013, 03:58 AM   #18
RobA_Oz's Avatar
QuoteOriginally posted by Anvh Quote
Now, you know that was Microsoft...
03-14-2013, 05:34 AM   #19
Anvh's Avatar
There might be a possibility that the blue update will come with an option to start at the desktop, but there are already ways to do that within windows 8 without additional software.
About the start button, well it's still there but it leads you to the metro menu... no idea if the blue update will do anything about that...
k-mount, pentax lens, slr lens
Why not make a Pentax LX digital? chaza01 Pentax DSLR Discussion 74 04-20-2014 02:51 PM
Why NOT a 300mm or 400mm Vivitar? magkelly Pentax SLR Lens Discussion 19 11-09-2012 07:46 PM
Do you use the in camera color settings? why or why not? SlickYamaha Troubleshooting and Beginner Help 13 08-13-2011 09:36 PM
Why I Am Not a Republican jeffkrol General Talk 20 07-08-2011 05:07 AM
why not something like this? - not a Pentax axl Non-Pentax Cameras: Canon, Nikon, etc. 131 09-27-2010 11:35 AM
All times are GMT -7. The time now is 10:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
