Originally posted by godwinaustin
Hi,
Bought my first M42 Lens and it is a Mamiya Sekor 135 2.8. It has the A/M switch to switch to manual and is NOT the SX version.
I am confused as to whether this lens can get stuck on newer bodies such as my K30 or if it is just the SX version of this lens that has mounting issues on pentax bodies.
Thanks!
Should work fine. Put the adapter on the lens first. That should give you a clue as to whether there are any issues. The mounting problem with the SX lenses is not so much that they get stuck as that they may not mount cleanly due to a "wrap-around" aperture ring that snugs up prematurely to the body flange on a K-mount camera. The result is a non-functional aperture ring and loss of infinity focus. There is a similar issue with some Helios 44-3 58/2 variants.
For the record, there are very few M42 lenses that have mounting issues on K-mount cameras. The most common problems are:
- No A/M switch
- Wrap around focus or aperture rings. (Some vintage M42 bodies features a very petite body flange paired with matching lenses that neatly hid the mount.)
- Large lens bodies that interfere with built-in flash housings (think fat mirror lenses)
- M42 bellows suffering from the same problem
- Proprietary mount features that physically interfere with a clean mount to the adapter
- Deep rear elements that interfere with mirror movement when adapted to Canon FF
